Relocated my coolant filter
Old Jun 30, 2012 | 03:15 PM
bpounds's Avatar
bpounds
I don't like things that are more difficult than they need to be. And I got annoyed by having to unbolt my coolant filter to get the element loosened and removed. I can barely get a filter wrench on it and then when it is loose it won't come up out of there. Why the heck did it have to be tucked so far down in there? No good reason.
So I relocated it upward with a simple sub-plate. Now I can get my hands around it, and it will easily pull up and out without spilling.
I didn't have any 3" wide stock around the home shop, so I grabbed a Simpson tie plate from Home Depot. This turned out to be a stroke of genius because the plate is the exact width of 3", and the nail holes are the correct center distance to fit the bracket. Just drill them out to 13/32", then cut the excess plate ends off. That lifts the filter head 2-5/8". It doesn't touch the hood, and is still below the top of the radiator.
Cost about $2 including bolts.
Old Jun 30, 2012 | 03:29 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
not bad. that original setup does look like it wasn't very well paced. a ton more room now. Did you make or buy the original setup?
I like the way Sinister did theirs. Although it would be nice to have just a bit more room like you now have.
here is mine
Old Jun 30, 2012 | 03:37 PM
bpounds's Avatar
bpounds
Mine is the dieselsite unit. About 2 years old.
Old Jun 30, 2012 | 04:57 PM
Misky6.0's Avatar
Misky6.0
I thought all mods needed to cost a lot more than that!?
REPS to you!!!
I'm off to Home Depot.. brb
Old Jun 30, 2012 | 08:43 PM
98SurplusExpy's Avatar
98SurplusExpy
I didn't like any of 'um ... so I custom fabbed my own with easy access a first thought in the design.
Ford4Life7.3
90
Jul 19, 2012 06:05 PM
B846B
Jul 7, 2012 11:30 AM
ROBBINthaHOOD
Dec 31, 2011 06:12 PM
TexasA&M
Aug 18, 2010 03:06 PM
98SurplusExpy
Mar 5, 2010 11:47 AM
