1978 - 1996 Big Bronco
Acceleration issue
Old Jul 31, 2013 | 10:40 AM
memphis88's Avatar
memphis88
Acceleration issue
So I noticed this on the way back from Pismo/SLO about two weekends ago and its done it a couple times since then.
I was driving along the highway at 65 and noticed I started slowing down so I put my foot into the gas more to get back up to speed and felt it downshift. I got it back to 65 and it wouldn't shift back up so I gave some more gas and it starting revving really high then shifted pretty hard once I hit about 70. it doesn't do it unless I'm driving it on the highway for at least 30ish minutes. If I run to Hanford which is about 20 minutes from base (speed limit 65) down 198 she shifts and runs just fine. Also, the truck doesn't have a tachometer.
I apologize for lack of in-depth info, but I don't know how else to really explain it.
Thanks for any help!
Old Jul 31, 2013 | 11:31 AM
GruesomeJeans's Avatar
GruesomeJeans
Well first things first, could ya provides the year, engine, trans for us?
That will allow us to get an idea of the monster you're dealing with.
Old Jul 31, 2013 | 11:44 AM
memphis88's Avatar
memphis88
88 with a 302 and the guy i bought it from said he switched it to a E4OD instead of the original AOD.
Old Jul 31, 2013 | 12:38 PM
GruesomeJeans
Did he switch over all the electronics for the E4OD? I think the computer needed to be changed along with the VSS in the rear axle but I am not sure. I don't have a lot of experience with these transmissions. Have you checked the fluid recently/what's the condition of it?
Old Jul 31, 2013 | 02:51 PM
Kemicalburns's Avatar
Kemicalburns
agreed,
to turn over drive off on that model you would have a button to push either on the dash or on the end of the gear shift.
Old Jul 31, 2013 | 03:02 PM
memphis88's Avatar
memphis88
theres no button on the dash or shift stick
Old Jul 31, 2013 | 03:03 PM
memphis88's Avatar
memphis88
on the shift indicator it goes park, reverse, neutral, overdrive, drive and 1.
Old Jul 31, 2013 | 05:01 PM
Kemicalburns
then you more than likely still have an AOD. the E40d is controlled by the computer and various other sensors to even shift properly.
take and post a picture of the trans pan. see if there is any identification numbers.
if you had been playing down at pismo in the sand its very possible you got the tranny reallyhot and possibly burned it up. the AOD isnt known for taking abuse. having the tranny fluid replaced and filter would be next step
Old Jul 31, 2013 | 05:50 PM
memphis88's Avatar
memphis88
I haven't played in the sand in a couple months, i just took it up on the beach and used it to play music while we had a bonfire.
Old Jul 31, 2013 | 05:52 PM
memphis88's Avatar
memphis88
Its gonna be till the 6th before I can get a pic, I'm in new york right for the time being. this is just the first time I've had the chance to actually get on here in a while.
Old Jul 31, 2013 | 06:54 PM
memphis88's Avatar
memphis88
Although I've played in the mud and some trails a couple times since then though. nothing to major that requires 4 low.
Old Jul 31, 2013 | 06:57 PM
memphis88's Avatar
memphis88
Also I just looked up the VIN, and the 302 isn't the original motor, it used to have the I6. The tranny is the AOD.
InsanePyro
Jun 25, 2025 05:42 PM
memphis88
Dec 3, 2022 04:01 AM
jfarcmaster12
Jan 16, 2017 10:26 AM
exhawgdoctor
Nov 6, 2013 05:01 PM
impish
Jan 31, 2013 02:18 PM
