Electric is way more expensive, and does not get it hot like the jet heaters do.
I had a wood stove in there before, when I worked out there every day/ I'd start the turbo heater, then start the wood stove. By the time the stove caught up, it was toasty in there
That heater will heat the whole garage, and then some. You will be pleasantly surprised
I had to do a slack adjuster on the Pete last winter, I just put up some tarps around it, and fired up that heater.
Down to t shirt, outside in the teens for a temp.
Okay, I might just do that then. Like I said, I'll have to put up a plastic wall, don't want to try heating the whole damn garage!
We have some old fire proof folding walls that a school used. They work really nice to separate the shop into 2 sections, that way we only have to heat half of it. Plus, they are fire proof, so they are very well insulated.
