Transmission service
Old Jul 29, 2013 | 09:21 AM
MBoyle1's Avatar
MBoyle1
I have a 2011 E-350 that's weighs 8500 LBS & I tow a 5000 LBS car/trailer A few times a year.Van has 20,000 miles.Does the convertor have a drain plug or can I just drop the pan & do the filter.
Old Jul 29, 2013 | 09:26 AM
Ford E-150 +'s Avatar
Ford E-150 +
In my 2010 E-150 4.6L I had too drop the pan... I you do, buy a new gasket. I dont think gaskets they are reusable.
Old Jul 29, 2013 | 07:08 PM
OSHS's Avatar
OSHS
Unless something has changed, I don't think your converter has a drain plug. Ford quit installing a drain plugs around MY 2000. My 99 4R100 has one, my 2001 4R100 does not. About half the fluid in the transmission is in the converter, so dropping/draining the pan will not be a complete change. On my 2001, I simply take it to a shop and have them flush it using a machine. They unhook the supply and return lines from the transmission cooler at the base of the radiator and hook those to their machine.
Old Jul 29, 2013 | 08:07 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Ford stopped installing drain plugs shortly after the start of the 2002 model year. Your 2001 had one when it left the factory. If it doesn't have one now it is not the original converter.
Old Jul 29, 2013 | 08:24 PM
OSHS's Avatar
OSHS
Mark, thanks for the info. I've looked two or three different times for a plug (had friend turning engine with a wrench once, the other two I did it myself) and never found one. I'm the second owner (purchased at 40K mi), so I'm not sure of the history.
ugh3012
Mar 8, 2016 10:45 PM
hav24wheel
Mar 6, 2013 01:44 AM
Jake_f16
15
Dec 8, 2012 07:45 AM
slomafarms
1997 - 2003 F150
Apr 20, 2011 05:41 AM
MJEmerson
Jan 28, 2004 11:29 AM
