How many qt for drain and fill in tranny
I just drain the transmission from the plug hole (I did not remove the pan) and put 3 quart of transmission fluid in it. The dip stick shows the level on the hatch area. But, only 3 quarts? I would think it would take more than that even though it is drain and fill method.
What is the best way to check the level in the transmission?
2001 F250 5.4V8 4 speed automatic transmission.
Thats why I check it before i drain it. should be in the 7-8 quart range thats what I got the last time I drained a 4r100 I pulled the pan though. But there wasn't that much in the pan after pulling the drain plug. the I always measure what comes out. Then you know it was full before you drained it and you know how much came out and how much you should put back in. Tom, didn't they get rid of the drain plug on the converter in either 2000-2001?
I do the same, it's tough to screw up when you measure what comes out.
Yep, I believe it was 2001. Which is why it's odd that the '04 shop manual instructs you to drain the converter.
It was August, 2001, which was well into the 2002 production. All 2001 trucks left the factory with a drain plug in the converter.
Draining only the pan should get 5-7 quarts out.
The level needs to be checked with the trans warmed up, after the shifter has been cycled to EVERY position, then left in Park, and the engine idling.
mooncricket
16
07-31-2008 03:55 PM
viperbluelx
03-29-2008 10:52 AM
Petiboy
09-16-2003 04:14 PM
