Fuel Filter problem
Old Jul 28, 2013 | 06:03 PM
4bigred's Avatar
4bigred
Fuel Filter problem
I went change the fuel filters today and ran into a problem with the cap on top filter. Darn near killed myself getting the frame mounted filter cap off and couldn't budge the top one. I was using the drive on my ratchet and asked my son the try. It's so tight that he broke the top where the rachet drive is inserted. I don't think it will leak. My question is this, we are leaving on a 4K mile trip pulling our 5th wheel. Can I wait to address this or do I need to replace the top filter since I got the new frame filter in? The filters were installed by my favorite garage and had 11k miles on them.
Old Jul 28, 2013 | 06:10 PM
big inch's Avatar
big inch
The broken cap shouldn't be hard to remove. The way I do them is drill 2 holes towards the outside of the cap directly across from each other. Then take 2 Phillips screwdrivers and insert them in the holes. While holding the tops of the screwdrivers with one hand, I put a long prybar through them near the cap and twist it off.
Old Jul 28, 2013 | 06:12 PM
big inch's Avatar
big inch
Oh, and when removing the cap in the future, I would recommend using a socket. I learned the hard way that the plastic cap is not too sturdy.
Old Jul 28, 2013 | 06:13 PM
4bigred's Avatar
4bigred
Do I have to get the cap at Ford or will an aftermarket do? Thanks for the idea.
Old Jul 28, 2013 | 06:14 PM
gwg42's Avatar
gwg42
Use only sockets to remove fuel or filter caps. Change the filters now before trip and get a new replacement cap from dealer. Don't over-tighten. There are lots of threads concerning oil and fuel filter caps being broken using a ratchet on this site.
Old Jul 28, 2013 | 06:19 PM
4bigred's Avatar
4bigred
The filters were replaced in the course of other work. When I do them I only tighten a little past snug, so using the rachet drive's never been a problem. Should have stopped and bought a socket. 25mm?
Old Jul 28, 2013 | 06:24 PM
4bigred's Avatar
4bigred
Can I get the cap at Autozone et al, or at Ford only?
Old Jul 28, 2013 | 07:02 PM
4bigred's Avatar
4bigred
Thanks for the quick responses. My son felt terrible and is relieved that the fix is that easy. Why I didn't try a socket is beyond me. We tried a 15/16 after the cap broke. Duh.
Old Jul 28, 2013 | 07:07 PM
69cj's Avatar
69cj
The O ring seals not the threads. Lube O ring with oil and tighten till it bottoms out and wrist tight is plenty.
Old Jul 28, 2013 | 07:43 PM
04badford's Avatar
04badford
I would stay with OEM cap and filter, just my 2cs
Old Jul 28, 2013 | 08:25 PM
69cj's Avatar
69cj
Agree 1 million per cent.
Old Jul 28, 2013 | 08:55 PM
CPB1's Avatar
CPB1
It happens to a lot of us, it's a common mistake. Good thing is it's an easy fix.
Riffraff Diesel: Fuel Filter Lid 03-07
Old Jul 30, 2013 | 07:43 PM
4bigred's Avatar
4bigred
I tried the screwdriver and prybar method. The cap wouldn't budge; I drilled a couple more holes and used a hacksaw to cut a wedge shape that I broke out. Then used the prybar and screwdrivers again. Finally got it to break loose. I got all the plastic out of the canister and everything seems okay. Pulled the 5th wheel 250 miles today.
Old Jul 30, 2013 | 11:10 PM
04badford's Avatar
04badford
Glad to hear the good news , those Caps with the O-Ring just need snug for no leak after filter replacement ,lube O-ring with oil and snug cap then check after truck has been running for awhile twist as needed
Firemudder
Feb 14, 2012 10:59 PM
scatgo
Jun 29, 2008 01:56 PM
fordf150guy
Jan 19, 2008 07:33 AM
Mindstream
Jan 8, 2007 03:26 PM
GTB
Mar 13, 2005 12:02 AM
