update no wts help
Jul 28, 2013 | 10:00 AM
update no wts help
Ok here is what I did with no go new ford cps/ new 22 fuse (15 amp) chip out power to the 22 fuse when key on only . took the pcm off d side fender shook it no water (look good ) I am at a lose what can be the problem I don"t have a code readerand need help
Thanks Again guys
Jul 28, 2013 | 10:09 AM
Unplug fuel bowl heater if you blew fuse 22.
Jul 28, 2013 | 10:18 AM
Yup been unplug for over 2 yrs
Jul 28, 2013 | 11:27 AM
IIRC that is the IDM (Injector Drive Module) that is on the driver side fender, while the PCM (Powertrain Control Module) is on the inside of the cab under the dash. It would be worth checking that as well. Someone please correct me if I'm wrong.
Jul 28, 2013 | 12:25 PM
Okay thanks but how would I test to know what one I need or if I can test them any help is helpful
Thanks
Jul 28, 2013 | 05:40 PM
Does that first post say you have a chip and took it out? It's hard to understand with no punctuation.
I don't know how/if you can test the pcm, but with no wts light and a new fuse in 22 it sounds like its either in the pcm or wiring to it.
Jul 28, 2013 | 09:17 PM
Jul 28, 2013 | 09:37 PM
Have you checked fuse 22 again ?
If its blown again you need to look at the fuel bowl heater wire to make sure its not shorting out on the block.
Edit: if you keep it all in one thread it makes it a lot easier for us to help you.
Here is the other one guys
https://www.ford-trucks.com/forums/1...wts-light.html
Kevin562
Nov 29, 2023 12:10 AM
Absolute
179
Sep 6, 2015 09:05 PM
70spoiler
Mar 30, 2014 03:45 PM
stonemason
Aug 2, 2013 09:58 PM
greagin
Jan 10, 2008 07:03 PM
