no wts light
Old Jul 27, 2013 | 09:35 AM
stonemason's Avatar
stonemason
no wts light
Hay guy's was on the road and the truck died I have no wts light and the tack wont move I did changed the cps and check the 22 fuse what am I looking at next Need Help
Thanks
Old Jul 27, 2013 | 09:57 AM
tshrager's Avatar
tshrager
Thanks
Unplug your fuel bowl heater wire and replace fuse 22 again. Did you use a Ford or International CPS?
Old Jul 27, 2013 | 10:05 AM
stonemason's Avatar
stonemason
Bowl heater was unplug but will look at fuse 22 again but what eles would I be looking for as the problem the truck is 20 miles away on the side of road oh it's 95 cclb 4x4 230000
Old Jul 27, 2013 | 10:09 AM
tshrager's Avatar
tshrager
Fuse 22 is used to protect the PCM, which is what the WTS runs off. No WTS means no power to PCM. Did you use a Ford or International CPS?
Old Jul 27, 2013 | 10:24 AM
fordpride's Avatar
fordpride
If the heater was unplugged then you may want to look at the fuel bowl heater wire to make sure it hasn't ground out on the block
Old Jul 27, 2013 | 10:40 AM
stonemason's Avatar
stonemason
Well I had a cps that was acting up in the glove box and tried that an no go . Called ford up an no go so until the ford cps comes in I have no luck but to get one from the parts store and pray I can get it off the side of the road
Thanks
Old Jul 27, 2013 | 11:28 AM
mattman347's Avatar
mattman347
Do you have a chip? If so pull it and try again. CPS won't effect your WTS light.
Old Jul 27, 2013 | 04:47 PM
stonemason's Avatar
stonemason
Update I installed a ford cps and replaced 22 fuse no go . I had the truck towed back to the house so I can work on it . I do have a bully dog chip in it I will pull it out an see but if not guy's what else would I check at a lose it's my dd help
thanks
Old Jul 27, 2013 | 05:20 PM
tshrager's Avatar
tshrager
thanks
Is that bully dog a programmer or a chip? Programmers are notorious for toasting PCM's.
Old Jul 27, 2013 | 05:50 PM
fordman67's Avatar
fordman67
Have yoou checked #22 for power? If it is powerless the fuse wont matter.
Old Jul 27, 2013 | 07:20 PM
fordpride's Avatar
fordpride
Check fuse 22 again.
No wait to start light means no power to the PCM
Old Jul 29, 2013 | 04:55 AM
stonemason's Avatar
stonemason
Thanks I pulled the chip and no go I have power to the 22 fuse . i think the pcm went out but not sure
Thanks
therigwelder
30
Dec 9, 2015 07:46 PM
westpsd
16
Mar 2, 2010 11:33 AM
jaco96
Feb 13, 2008 03:37 PM
LUMBERMAN
17
Dec 23, 2007 05:10 PM
MikeSDK
13
May 11, 2007 09:43 PM
