Bad Problems..
Old Jul 21, 2013 | 05:57 PM
charles09's Avatar
charles09
Bad Problems..
Truck Info:
93.5 F-350 7.3 Factory Turbo Engine
Had Injector pump replaced & injectors about 3,000 miles ago.
I made the mistake of not taking it back after I drove it for first time but my truck is smoking really blue @ idle and it smokes going down the road.. It uses about a gallon of oil every week as well? I am sure that is not normal.. where do I start on diagnosis?
Old Jul 21, 2013 | 07:47 PM
Ford F834's Avatar
Ford F834
Blue smoke and oil consumption (if it wasn't doing it before the IP injector job) sounds like a clogged CDR, or blocked/pinched crank case vent hose. Smoking going down the road, if you mean black smoke, could be restricted air intake/filter, IP timing, or the fuel screw is turned up too high on your new IP.
Old Jul 21, 2013 | 08:33 PM
charles09's Avatar
charles09
I took the cdr off and soaked it in some gas. while doing that I broke gromet off the bottom of it but got a replacement should I had replaced the CDR?
Old Jul 21, 2013 | 10:02 PM
Ford F834's Avatar
Ford F834
Try this to see if it is working...
Originally Posted by IDIDieselJohn
You can try cleaning yours if you think it doesn't work correctly. Soak it in gasoline for a few hours, and once in a while, take it out, shake it, dump it out etc, and let it soak some more.
Then let it AIR DRY, do NOT blow compressed air through it, you will blow the diaphram.
Also to test if it works correctly, on the top part of it, there will be a very little vent hole, put your mouth on it, and stick you finger in the bigger hole where the connects to the back of the intake, and blow, you should feel the diaphram move inside with your finger, if it doesn't move, it is bad.
It is a Ford/International dealer part only, and not cheap.
Old Jul 22, 2013 | 06:39 PM
charles09's Avatar
charles09
I didn't blow on it I guess ill take it off an soak it in gas again.
Old Jul 22, 2013 | 07:11 PM
Ford F834's Avatar
Ford F834
You can also try driving with the oil filler cap removed. If it helps you know your problem is crank case vent related...
Old Jul 22, 2013 | 07:54 PM
charles09's Avatar
charles09
Wont this spray oil everywhere?
Old Jul 22, 2013 | 09:55 PM
Leftyizme's Avatar
Leftyizme
misread the year.. thought you had a powerstroke.. sry post deleted
Old Jul 22, 2013 | 09:59 PM
Macrobb's Avatar
Macrobb
I've done this, answer is no. You might lose a few drips, but not a whole lot. I've done it(by accident).
Old Jul 23, 2013 | 02:34 AM
Ford F834's Avatar
Ford F834
If it sprays oil everywhere, you have a lot worse problem than a clogged CDR, that's for sure. Mine "fumes" a little, but isn't wet at all, and I have quite a bit of cc vapor.
Old Jul 27, 2013 | 09:05 PM
charles09's Avatar
charles09
It doesn't spray oil everywhere however there is a considerable amount of white fumes coming from the filler neck. Not drove it enough to notice a difference in usage of the oil.. also still same amount of blue smoke coming from exhaust while idling.
OldSchool68
Feb 17, 2024 02:45 PM
Mike444z
Nov 18, 2012 04:27 PM
442john
Jul 3, 2007 09:35 AM
billydavis1
Jul 7, 2004 07:17 PM
donblue
Sep 23, 2003 10:25 PM
