Injector O ring replacement
Old Jul 6, 2004 | 02:05 PM
billydavis1's Avatar
billydavis1
Unhappy Injector O ring replacement
I have been told by my mechanic that replacing the o rings on the injectors is a maintainance item that should be done every 75 k or so. He said that this is the reason I am using oil at the rate of less than 1000 miles per quart. He said that the 7.3 psd is virtually indestructible and that it is not in need of a overhaul at 83000 miles. I have no other symptons. It runs with full power and no great amount of smoke at startup. What do you think?
Old Jul 6, 2004 | 04:24 PM
International Tech's Avatar
International Tech
No need unless you are having problems w/ them. @ 83k she's just now getting broke-in!
Old Jul 6, 2004 | 05:58 PM
johnsdiesel's Avatar
johnsdiesel
I agree with your mechanic. That kind of oil consumption is usually the result of failing injector o-rings. Is your fuel filter black when you change it?
Old Jul 7, 2004 | 12:09 PM
Rancha9's Avatar
Rancha9
My filter was black when I changed it the other day... Not to mention I have some minor white smoke on startup and when idling for more than about 5 minutes... I take it this is a sign of bad o-rings... Well, should I just go ahead and replace them now while I have the turbo ripped off? It'd probably be easier anyway. Is this a good part to get from the stealership, or an aftermarket company?
Old Jul 7, 2004 | 12:22 PM
johnsdiesel
Yes, that is a sign that the injector o-rings are failing.
Old Jul 7, 2004 | 07:17 PM
slc10844's Avatar
slc10844
What year truck is it? With 83K miles, it should be a warranty item.
