Stalls at stop lights
Old Aug 1, 2013 | 07:59 PM
pawpaw's Avatar
pawpaw
OK, good, so is it idling ok now, not stalling when coming to a stop????
With no dash warning lights being lit after it stalls, suggests a power problem to the computer, so have you tried swapping out the under hood computer power relay located in the power distribution box, with a known good like relay not needed to run the engine, like the AC power relay????
If you've swapped the power relay without joy, when it stalls, will the interior, or head lights still light up????
Old Aug 1, 2013 | 08:22 PM
wheelchairdude49's Avatar
wheelchairdude49
stalling
Runs and idles but when you go to step on the gas it bogs down and then clears up when it gets warm.
s
Old Aug 1, 2013 | 09:26 PM
pawpaw's Avatar
pawpaw
OK, so I take it that the stall when coming to a stop problem has been fixed, right????
When its cold & acting out & not wanting to go at throttle up, do a fuel pressure & fuel delivery volume rate over time test, with a fuel pressure gauge connected at the fuel rail Schrader valve test port & post the Numbers.
Still no CEL/SES light lit?????
Old Aug 1, 2013 | 09:35 PM
wheelchairdude49
no cel lit. Stall at light fixed. I will test it as soon as i can.
Old Aug 1, 2013 | 10:04 PM
pawpaw's Avatar
pawpaw
On the engine stall with no dash warning lights lit, let us know how it goes after you swap out the AC for the computer power relay.
Old Aug 3, 2013 | 03:52 PM
wheelchairdude49
Stalling
It didn't make any difference Swapping out the relays. Still getting a stall when warmed up and restarting the truck.Got gas and turned it over and it started and then stalled. Then ran fine.
Checked fuel pressure.
KOEO 62lbs.
KOER 68
when i shut it off it leaked down 60 lbs.
Thanks
Old Aug 3, 2013 | 03:53 PM
wheelchairdude49
Only 4000 miles on fuel filter.Should i put a new one on it?
Old Aug 3, 2013 | 08:10 PM
pawpaw's Avatar
pawpaw
Ok, good testing & feedback. Not likely a need to replace the fuel filter with only 4K miles on it.
Our fuel pressure needs to be between 64 +/- 8psi, so your pressure is ok. BUT, how long does it take to leak down to 60psi???? What does fuel pressure look like after say 30min after a hot engine shut down?????
Before restarting after a hot shut down, what happens if you cycle the ignition switch from Off to On, pausing at On long enough for the fuel pump to cycle on then time out & turn itself off (about a 2 second pause at KOEO), say do it 3-4 times, Then crank the engine, does it then not hot stall after a start????
If no stall joy after cycling the ignition switch before a hot restart, are you certain that the vapor pressure of the fuel your using is within specification for your area. I'm thinking vapor lock after an engine shut down hot soak!!!!
Old Aug 3, 2013 | 08:33 PM
wheelchairdude49
Stalling
will check fuel pressure at the begging of the week.
Old Aug 6, 2013 | 02:02 PM
wheelchairdude49
Stalling
I cycled the fuel pump and it still stalls after warmup and short cool down.
Old Aug 6, 2013 | 03:22 PM
pawpaw's Avatar
pawpaw
OK, well be sure to get a fuel pressure test at the fuel rail when it stalls & post the Number. If fuel pressure looks ok, do a spark test with your inductive timing light on any plug wire, to see if spark is going missing.
Old Sep 10, 2013 | 03:00 PM
wheelchairdude49
Stalling
Haven't had a chance to do that yet. Changed plugs in it last weekend.
Still had stalling issues. Plus i lost a brake line on the way home. Yikes!
What size would i need to replace the line from the front to back and how many feet?
Thanks
Old Sep 10, 2013 | 03:15 PM
  #28
wheelchairdude49
By the way when I move one of the plug wires on top of back coil engine almost stalled.
Don't know what that might indicate.
Old Sep 10, 2013 | 06:29 PM
  #29
C. Lee Colbert's Avatar
C. Lee Colbert
Sounds like the wire from the coil is intermittant, how old is it?
Old Sep 10, 2013 | 07:39 PM
  #30
wheelchairdude49
Stalling
Plug wires only have 4000 on it. coil pack itself is as old as the truck.
13 years
