A few questions
Old Jul 17, 2013 | 09:10 PM
Wood.'s Avatar
Wood.
A few questions
I have what i believe is a 92 f250. manufacture date is 8/91
i have the newer body style and speedo in rear end.
my question is my cruise control isnt working, where should i begin to look in tracking down the issue.
its an xlt f250 4wd supercab long bed zf5 speed. my grandpa (previous owner) said it stopped working after a clutch install. dont see how this would be related but thought id add fwiw.
Old Jul 17, 2013 | 11:12 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Check that the vacuum shuttoff switch on the brake pedal is adjusted correctly (think brake light switch but vacuum). Could have been bumped when under the dash or something, is often missed. From there make sure all electrical and vacuum connections are good relating to the CC. Make sure the CC cable is hooked up to the throttle cable on the IP.
Old Jul 18, 2013 | 08:04 AM
Forddiesel17's Avatar
Forddiesel17
IIRC there should be a switch on the clutch pedal also to disengage the cruise. Not sure where exactly it's at though.
gfarmer
Feb 11, 2019 02:32 PM
reamer
Apr 11, 2015 08:08 AM
arborfet
Mar 7, 2015 07:45 PM
DesertZuki
Jan 7, 2015 11:25 AM
dyoungen
Jan 16, 2012 02:53 PM
