Clutch Pressure Switch Question (solved)
Old Jan 2, 2015 | 11:06 AM
DesertZuki's Avatar
DesertZuki
1986 F150 Lariat 302 with manual 4-speed overdrive.
Is the pressure switch that is activated by the clutch pedal in the "up" or "engaged" position -- is that for cruise control? (Not the clutch disengaged/starter switch.)
Old Jan 2, 2015 | 11:19 AM
ctubutis's Avatar
ctubutis
Could be... what colors are the wires?
Old Jan 2, 2015 | 12:44 PM
Franklin2's Avatar
Franklin2
Probably. Is there two? There should be two on the brake pedal. One is a electrical switch to tell the cruise brain to turn off, and the other one has a vacuum line going to it, and dumps the vacuum out of the cruise servo so the speed drops quickly.
Old Jan 6, 2015 | 11:29 AM
DesertZuki's Avatar
DesertZuki
Sorry for the delay of game; life gets in the way...
The wires are both black. I can't say for sure they don't have another color on them, but it doesn't look like it. I'll look for a vacuum line and report back.
I don't know what else it could be. I guess I could run it down the road and test it. Will advise...
Old Jan 7, 2015 | 11:25 AM
DesertZuki's Avatar
DesertZuki
A road test does indicates it is for the speed control. Thanks for the help.
sstouder
13
Mar 2, 2019 07:39 PM
reamer
Apr 11, 2015 08:08 AM
cornking
Sep 13, 2011 10:08 PM
MSC1
Jan 14, 2007 11:15 AM
MikeB 88
Feb 3, 2006 07:19 PM
