Prop valve.
Old Jul 17, 2013 | 07:46 PM
elkarcher1716's Avatar
elkarcher1716
Prop valve.
Where should I mount the proprotioning valve on my 75 HB? I got the brake lines ran up to the front and had to stop there cause im not sure where i should put the prop valve. any ideas? I got the bracket and stuff from the donor 74 2wd just not sure where to put this thing.
Tim
Old Jul 17, 2013 | 08:51 PM
hickory1991's Avatar
hickory1991
Hope this pic helps. Right under the z-bar for a manual trans. Should be holes to mount bracket to.
Old Jul 18, 2013 | 08:58 AM
elkarcher1716
thanks for the pic. I was thinking about there also. Just got to fab something to bring it out a little away from the frame. Thanks again.
Tim
Old Jul 18, 2013 | 09:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by elkarcher1716
Where should I mount the proportioning valve on my 75 HB?
Your truck already has a proportioning (Brake Pressure Differential) valve (see 2B257 in pic). All 1967 and later FoMoCo vehicles with dual master cylinders came with one.
If you swapped in disc brakes, the valve is different than used with drum brakes.
C8TZ-2B257-C .. Brake Pressure Differential Valve / 1968/75 F250 4WD
D5TZ-2B257-B .. Brake Pressure Differential Valve-Use with disc brakes / Marked: D5TA-2B524-FA or FB
1975/79 F100/150 2WD & F250 2WD with single piston calipers / 1975/79 E100/150 / 1976/79 F100/150 4WD & Bronco / 1976/79 F250 4WD / 1979 F350 4WD
Old Jul 18, 2013 | 10:40 AM
elkarcher1716
Thanks Number dummy for the part numbers. I did swap in disks up front. I was going to use the one from the 2wd donor truck i bought. It had front disk brakes.
Old Dec 7, 2013 | 02:53 PM
elkarcher1716
hate to ask but can you get a pic of the bracket cause I am having an issue with mine. I might have the wrong one or something.
Thanks Tim
Old Dec 7, 2013 | 04:12 PM
hickory1991
Give me a little while and i will go out and see if i can get a pic of it.
Old Dec 7, 2013 | 04:13 PM
elkarcher1716
cool thanks
Old Dec 7, 2013 | 05:18 PM
hickory1991
Hope these help. Truck is a little more assembled than previous picture. Bracket mounts on inside of frame and spaces prop valve just past edge of frame. It's bolted to thru frame from outside. See pic with two angled hex head bolts. Prop valve then bolts to bracket. Kind of a c-hannel type bracket with nuts welded on inside of bracket. Maybe your frame is pre-drilled for bracket maybe not. Tried to show shock to give you an idea of location.
Old Dec 7, 2013 | 05:43 PM
elkarcher1716
Wow thanks, only problem is I never took a bracket off like that. Now i have to find or make something. thanks a million. trucks looking good.
Tim
Old Dec 8, 2013 | 04:50 PM
elkarcher1716
lucked out and found the bracket at the salvage yard. thanks for the help.
tim
Old Dec 8, 2013 | 04:54 PM
hickory1991
I was going to suggest that. Glad I could help.
Jim Lovell
Jun 8, 2019 10:20 AM
Tex51
Apr 25, 2019 08:14 PM
captainwoot
Jan 8, 2018 06:44 PM
belshe92
Jun 2, 2016 11:51 PM
OldHarley
Apr 5, 2010 10:24 PM
