Sponsored by: Real Truck
cab light spacing
Old Jul 17, 2013 | 05:33 AM
ho_shi's Avatar
ho_shi
cab light spacing
what is the factory cab light spacing for a 07 super duty with sun roof??
looking for measurements from the front window seal and sides....
looking to install aftermarket vms racing smoked lights on my 07 outlaw and just want it to look good... have read several threads on installing but dont remember seeing the measurements
Thanks, AJ
Old Jul 17, 2013 | 07:49 AM
framersteve's Avatar
framersteve
I put mine @ 8" and 13" from center. 5.5" from rubber windshield seal. I think it is @ 42" from center to center of outside lights. That is pretty close to factory.
Old Jul 17, 2013 | 02:01 PM
ho_shi's Avatar
ho_shi
got pics of the install?? and after
Old Jul 17, 2013 | 05:29 PM
bpounds's Avatar
bpounds
This tells you pretty much all you need to know:
F250 Factory Clearance Light install
And here are some comments I made after I installed mine.
https://www.ford-trucks.com/forums/7...ostmortem.html
Old Jul 17, 2013 | 06:12 PM
Shake-N-Bake's Avatar
Shake-N-Bake
My dimensions are very close to what bpounds posted.
When I did my wife's truck, I obtained the lights from a F-450 at a salvage yard. Once the lights were removed, I laid a piece of pattern paper on the cab and traced the location of the holes. I think the aftermarket lights work with a 7/8" dia hole but the OEM lights that I had did not....I had to enlarge the hole a little bit to get them to fit. I think I ended up with 1 1/8" or something like that...
Here is the pattern file I made.
File Type: pdf
Old Jul 17, 2013 | 06:15 PM
Shake-N-Bake
Here is the thread I posted when I did mine...
https://www.ford-trucks.com/forums/1...hts-today.html
Old Jul 17, 2013 | 06:58 PM
TexasRebel's Avatar
TexasRebel
if you use a greenlee punch put the little piece on the outside and pull it inward.
Old Jul 17, 2013 | 09:32 PM
ho_shi's Avatar
ho_shi
thanks for the great diagram!!
thanks for all the help guys.... would a unibit very carefully be to much? when you say a greenlee punch i think of a elec box knockout tool?
Old Jul 17, 2013 | 10:51 PM
bpounds's Avatar
bpounds
Lots of guys use a uni-bit. Others use holesaws. All work fine. Yes, a Greenlee is a knockout punch. They are a bit pricey, but you can rent them.
Old Dec 9, 2023 | 11:20 AM
P Diesel's Avatar
P Diesel
3rd Gear
2000 f250 cab lights
Has anyone ever evenly spaced cab lights on a 2000 to 2016 super duty f250 or f350? all I've seen is the 3 middle ones evenly spaced and the 2 side ones are spaced different but I want to make them even.
Old Dec 9, 2023 | 11:25 AM
P Diesel's Avatar
P Diesel
3rd Gear
If so can someone give me the measurements
Old Dec 10, 2023 | 02:06 AM
INFRNL's Avatar
INFRNL
probably should have just started your own thread.
Technically you can space them however you want. Just measure it and figure it out.
the way they are normally setup has been the standard since the beginning of time. there is most likely reason for it. Although I noticed Dodge has used equalish spacing IIRC. everything else uses the national standard
Old Dec 10, 2023 | 09:12 AM
P Diesel's Avatar
P Diesel
3rd Gear
Ok thanks I'll probably do some research but I wanted to know if anyone had ever evenly spaced cab lights on a ford, because I've seen all the Dodges have evenly cab lights.
Old Dec 10, 2023 | 10:59 AM
bpounds's Avatar
bpounds
Wow, 10 year old thread, and all the links still work.
You have everything you need in this thread to figure out equal spacing. The outer holes will still be in the OEM location, and the center hole will be also, you'll just move the last two outward slightly. The math is so simple that I feel I would be insulting you if I did it for you.
kd2dwj
Sep 4, 2018 07:19 PM
peka
15
Dec 4, 2015 03:28 PM
moose7289
May 14, 2008 09:15 AM
thematkave
Dec 20, 2005 11:47 AM
