cab clearence lights HELP
Old Nov 30, 2015 | 03:29 PM
peka's Avatar
peka
can anyone help? looking for non LED cab clearance lights that seal to roof. I got some but, they had flat mounting and there was a gap under front and rear of light not giving a seal. This is a 84 f250
Old Nov 30, 2015 | 03:52 PM
roadrash63's Avatar
roadrash63
I had some from a company called
Grote had to order them in.
Don't remember much else.
Old Nov 30, 2015 | 05:05 PM
madpogue's Avatar
madpogue
Cab Marker Light Yellow, 25760Y, Truck-Lite - EXACTLY the same as OEM.
Old Nov 30, 2015 | 05:10 PM
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by madpogue
What he said^^^^
That is as long as the holes are in the correct spots
Old Nov 30, 2015 | 09:54 PM
ent48f5's Avatar
ent48f5
Did your truck originally have them? I have a complete set of 5 off an 85 f350, pigtails, seals and harness. All ford. The lights aren't show quality, but are functional. If that's all you need, PM me.
Old Dec 1, 2015 | 12:02 PM
peka's Avatar
peka
Thanks everyone, after searching I think the Blazer/Optronics clearance lights will work best, they are not flat on the mounting and you do not have to remove the whole light to change bulb and only 20 for set of 5 with wiring at O auto parts.
Old Dec 1, 2015 | 04:01 PM
Diesel_Brad
Good luck with cheap k-mart lights
Old Dec 2, 2015 | 09:15 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
I found "OEM Style" replacement clearance lamps on Amazon, which are not LED's, using 12v, trade #194 blade bulbs.
I can't remember seeing clearance lamps at K-Mart since the 1970's....
Old Dec 3, 2015 | 06:53 AM
Diesel_Brad
K-mart sells Blazer lights
Old Dec 3, 2015 | 10:21 AM
peka's Avatar
peka
Well I got the Blazer lights, do not seem very cheap. Came with everything needed. The fit is far superior to ones costing much more and the lens comes off to replace bulb unlike the more expensive ones were you have to remove the whole light to replace bulb. These are much better than the OEM ones I had before in fit and looks. Blazer is a big company and sells there lights everywhere, sears, target, lowes, home depot. For 20 bucks you get 5 lights, wiring, switch, wire connectors, everything needed. To me this is very cheap priced for a better than OEM light.
Old Dec 3, 2015 | 11:11 AM
madpogue's Avatar
madpogue
This just means one more place for water to potentially leak in.
Please remember to post back to this thread 15-20 years from now and let us know how they're holding up compared to the OEMs.
Old Dec 4, 2015 | 07:00 AM
Diesel_Brad
EXACTLY......
Old Dec 4, 2015 | 11:54 AM
peka's Avatar
peka
Well my truck is 31 years old now and has cancer so bad it may not last a couple more years, so in 15-20 years it will be long gone and I will be getting close to 90, most likely long gone also. So I'm sorry to say I will not be able to post back to this thread and tell you the lights are still shinning brightly. But I will say this, I'm very happy with them now.
Old Dec 4, 2015 | 01:36 PM
WhatsAChevy?
Whoo Rah !
Well said !
Old Dec 4, 2015 | 03:10 PM
madpogue's Avatar
madpogue
In 15-20 years, depending on whether/how the you-know-what hits the you-know-where, today's gadget-mobiles may be the ones that are "long gone", and our 45-50-year-old completely non-electronic trucks may be the ONLY things still on the road....
