1990 Ford F250 e4od getting hot
I have a 1990 e4od with 83k miles on it. It has been serviced reg and lubeguard red added. I installed two hayden rapid cool trans coolers in front of the condensor and after the rad cooler. it runs at 150 around town and maybe 190 on the hwy. When towing a 3k lb trailer yesterday in 90 plus heat (some hills ) doing 60 on the hwy it hit 240/250 degrees. I installed the switch to lock the torque conv but i really did not notice an improvement. I called hayden and asked about changing the t stat to a 160 and bypassing the rad cooler and he said it would not matter. What should i do?
If it was my truck, I'd ditch the radiator cooler anyway, since your running a thermostat anyway.
I ordered a new rad to eliminate that possibility. I live in area where it gets very cold so I do not want to eliminate the rad cooler.
brian_06328
22
09-18-2015 09:25 AM
Old93junk
12-01-2008 05:58 PM
Gr8ride
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
04-08-2004 10:52 AM
stormyone
08-13-2003 09:51 PM
