E40D issue
Old Jul 15, 2013 | 12:15 AM
machinist91's Avatar
machinist91
E40D issue
Hey everyone,
so my 1992 F-250 7.3 4X4 has a very intermittent issue with the E40D. Rarely, usually after a lot of around town driving (I don't know if that has any direct correlation), I will get a rough shift from 1-2. It will kind of bang into gear and make the whole truck shudder. On one of it's episodes, it also did it in 2-3, however that only happened once and I haven't been able to make it do that again. I'm worried that it's something that I should address, if I can do so without just rebuilding the whole transmission. It doesn't slip and shifts fine most of the time, other than the occasional 1-2 issue.
To cut this short, does this sound like a 1-2 accumulator issue? Maybe just old truck syndrome?
I feel like this is a dumb as hell question, but isn't it a bad idea to install a shift kit in an E40D with 126K miles on it?
Thanks for any advice,
Dan
Old Jul 15, 2013 | 06:03 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Does the OD OFF light work? Is it flashing when it shifts hard?
Old Jul 15, 2013 | 09:55 AM
machinist91
Unfortunately, it does not work. Are you thinking something electrical?
Old Jul 15, 2013 | 11:24 AM
Mark Kovalsky
Maybe, maybe not. The PCM will store error codes when something is wrong. When it stores codes it flashes the OD OFF light to tell you there are codes. You probably have codes stored and you need those codes to diagnose what's wrong. Get them read. The auto parts stores CANNOT read these codes, it takes either a good independent shop or a Ford dealer.
shawbran
Nov 13, 2024 12:53 PM
Friendly02
28
Apr 9, 2018 05:26 AM
Sara_gael
May 15, 2017 11:10 PM
scottddove
84
Sep 7, 2014 10:34 PM
cmiller1229
Mar 12, 2010 07:33 AM
