Trip Report
Old Jul 14, 2013 | 10:02 PM
carbon coupe's Avatar
carbon coupe
Trip Report
Had my first long range towing job this weekend with my Ex. I went out empty and back with a 3400 lb car in the trailer. So about 7000 lbs total. I installed a rear sway bar before leaving, fueled up and away I went.
I went to PA and back, about 1000 or so miles. My towing mode was leave it in OD and keep throttle position constant going up hills. If enough speed is lost, the truck will downshift itself. Worked great. Got there, loaded the car, slept and left in the morning.
On the way home, in about the last quarter of the trip, something strange happened. Stopped for a stretch and some gas and when we left, it took a while to shift out of first gear and the OD "off" light started blinking. Back in town, I had to now lift to get it to shift into second gear. The rest of the shifts were fine and the trans seem to work fine. Once home, I let it idle while unhooking and then opened the hood and put a fan on it, engine off of course.
History: Purchased vehicle with 168K and the PO stated that he never touched the trans. I could tell he never towed with it either. Grocery getter mostly.
On the way to the house, I almost always had to lift to get the 1-2 shift and the OD light was still blinking. Again, the rest of the shifts and the trans in general seemed to be working fine.
On another note, the truck handled perfectly. No wandering, smooth ride and there was no tail wagging the dog. I have a 24' enclosed tag.
Im calling my trans guy tomorrow and I have a feeling I know what hes going to tell me. Any advanced advice would be appreciated.
A link for "Jeffs Trans Fund" is on the way.
Old Jul 14, 2013 | 11:15 PM
Stebs's Avatar
Stebs
Hopefully your trans guy can pull that trans code for you (OD flashing). If not, take it to a ford dealer and have that trans code pulled before you start dumping cash into the tranny. Most code readers WON'T pull the trans codes...
Old Jul 15, 2013 | 02:42 AM
Stewart_H's Avatar
Stewart_H
Mark K will have to chime in to confirm, but it sounds like you have one of the '01's that came with the Mechanical Diode and it went out on you.
Originally Posted by Mark Kovalsky
If it came out of a 2001 diesel there is one difference. It might have a mechanical diode intermediate one way clutch. If it does, you MUST replace it and several other mating parts with a sprag type one way. Any transmission parts supplier will have the right parts. If you don't replace it, I guarantee that it will break.
Stewart
Old Jul 15, 2013 | 09:59 AM
carbon coupe
Stewart
Yup, thats what my trans guy said. Just talked to him. $1850 gets me a new convertor and a rebuild with all the latest updates. Several were mentioned. I also mentioned my dually and he said it would have the same ability and durability.
He said I could probably nurse it for a while. Thats good because I wont have another car to drive for about a month. Theres other issues but those can be worked out.
Cant wait until its done. Love having a bullet proof trans in something I tow with.
Old Jul 17, 2013 | 10:43 AM
carbon coupe
Jeez, this trip also took out my vacuum pump. Only have defrost and the 4x4 wouldnt switch. Have a new one tomorrow, 135 clams at the dealer. Was going to buy at Napa but read a lot about very loud aftermarket pumps. I like OEM anyway, tested tough!!
Old Jul 17, 2013 | 05:22 PM
Stebs's Avatar
Stebs
Did you test the pump? Or did you just break a vacuum line somewhere?
Old Jul 17, 2013 | 08:56 PM
carbon coupe
Checked all the lines. In fact, removed the 4x4 lines. My truck has manual hubs.
I pulled the pump and put power to it....nothing. Checked power to the pins, bingo. Opened it up and there was corrosion and a broken wire. It was separated from inside the motor.
Im going to install it in the parking lot. Have the tools in the truck and cleaned up the bracket already. Should take all of 5 minutes.
Old Jul 19, 2013 | 11:56 AM
carbon coupe
The new ford pump came with the bracket. Installed in 2 minutes and pumped up fairly quick. Now the AC blows at me instead of the windshield.
Now if the trans was that easy.....and cheap.
sccamper
Apr 6, 2013 08:02 PM
beanhead6D5
Jul 26, 2012 09:51 PM
tshrager
22
Feb 3, 2012 06:09 AM
warmdye
Jun 13, 2002 09:52 PM
