Heater Valve
Old Jul 12, 2013 | 07:51 PM
LARIAT 85's Avatar
LARIAT 85
Heater Valve
Does hot coolant supposed to flow to the heater core ALL the time on the Bullnose trucks?
I noticed an older 1979 F150 had a heater valve inline with one of the heater hoses to shut off the hot water through the core when you are using the air conditioning. I can see how that would be more efficient and make the air cooler.
I don't see one at all on my 1985 F150 with factory A/C, just two heater hoses running from the intake to the heater core, and another from the heater core to the water pump.
Does my truck supposed to have this valve?
Old Jul 12, 2013 | 08:40 PM
Franklin2's Avatar
Franklin2
No valve. Some Fords had the valve, some didn't. It depends on the design. The old mustangs don't have a valve.
Some people add one in to help their A/C when the doors get leaky. I will see if I can find the article, I added one on my 89. It's a pretty cheap modification.
Old Jul 12, 2013 | 08:45 PM
Franklin2's Avatar
Franklin2
Here's the article. I was surprised how cheap the valve was.
Heater Core Bypass
Old Jul 13, 2013 | 08:01 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Wow, that guy did a lot of plumbing with ball valves and everything just to add a filter.
I've heard of the Ranger mod, but never felt the need.
Having the vacuum hooked like that would bypass my heater core on real cold mornings when I have the control set to recirculate, trying to warm up the air in the cab.
Maybe not an issue for those in warmer climates.
Old Jul 13, 2013 | 12:41 PM
Franklin2's Avatar
Franklin2
Yea, some of those guys are big rig diesel guys, and they have that type of stuff on those trucks, so they transfer those ideas down to the "little" trucks. Some of those filters have chemicals in them that slowly release into the coolant to keep things corrosion free. Like I said, that's all big rig million mile stuff.
Old Jul 13, 2013 | 12:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350 & 1978/79 Bronco only have a vacuum controlled heater water valve (D4AZ-18495-A) IF factory installed integral A/C or Hi/Lo Comfort Vent System is present.
No heater water valve is illustrated/listed for 1980/89 F100/350 & Bronco (except w/auxillary heater).
Left lower pic: 1980/86 F100/350/Bronco heater hoses / Right: Applications for 18495 heater water valves ~ A: Aerostar; B: Bronco II; E100/350: Econoline; R: Ranger; U150: Bronco.
Old Jul 15, 2013 | 02:04 PM
1986F150six's Avatar
1986F150six
Jim,
One can put a "tee" in the vacuum line which goes to the servo motor on the firewall on the passenger side. This motor closes the door when "max a/c" is used. The other side of the "tee" is connected to a vacuum controlled valve spliced into one of the heater hoses. This way, when vent, heat or regular a/c is selected, there is heat available, but when the selector is set for max a/c, the heater core is bypassed.
It works!
Old Jul 15, 2013 | 02:28 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have no A/C...
But when I want my cab warm, I want to recirculate the already lukewarn cabin air... not send subzero outside air through the heater core for only one pass.
On my control panel this is labeled 'outside air- off'
Old Jul 15, 2013 | 04:06 PM
f100beatertruck's Avatar
f100beatertruck
How about removing the vacuum control motor and using a manual choke cable to hook up to the arm on the valve. Then you'd have manual control over the valve and could close it in the summer and open it in the winter.
Or, you could add a Dorman 911-603 Vacuum Switching Valve for Toyota Evap system and wire it up so it cuts off vacuum except in Max AC mode.
Old Jul 15, 2013 | 07:51 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I think I would just go to a cable operated 5/8" heater valve if it were me.
http://www.ebay.com/itm/Four-Seasons-Cable-Operated-Pull-to-Open-Heater-Valve-5-8-74828-/111119733090?pt=Motors_Car_Truck_Parts_Accessories&hash=item19df409162&vxp=mtr
Cheap and not much to go wrong.
I've "fixed" the brittle vacuum line to that flap too many times.
Old Jul 15, 2013 | 08:53 PM
f100beatertruck
Does it matter that there's no flow though the heater hoses? The Explorer/Ranger valve loops the coolant back to the engine.
Old Jul 15, 2013 | 09:03 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
My 460 has a bypass hose from the intake back to the pump.
It doesn't matter one bit if there is water flowing through the core (or recirculating through the cutoff)
Besides it would ONLY matter before the thermostat opens.
It is nice that I get heat before the engine reaches operating temperature.
It has been hot and sticky here.
I am rockin' the 2x60 A/C
Old Jul 16, 2013 | 11:44 AM
Franklin2's Avatar
Franklin2
On certain setups it does matter, others not. For instance the guy with the coolant filter it would matter, since it would stop the flow in the filter.
Some of the older Fords had a clip that put the heater hose against the choke housing on the carb, it would matter then. Anything that is tied into the heater core loop would make it matter. On my truck I used to have electric fans. I put the temp sensor inline with the heater hose with a couple of fittings, so it would matter in that setup also.
But most vehicles with just plain heater hose going to the core don't care if there is flow there or not.
ramarado
Nov 22, 2008 10:59 PM
rsulvan
22
Mar 29, 2007 12:24 AM
Frank Kistner Sr.
Aerostar
13
Feb 3, 2005 03:32 PM
user 5363849
Jun 16, 2004 06:35 AM
borland
Mar 22, 2001 02:31 PM
