Heater control valve?
Old Nov 22, 2008 | 12:10 PM
ramarado's Avatar
ramarado
Does a '73 with NO A/C have any type of a heater control valve, and if so where the heck is it, or does the water run through the core all the time? I can see the two heater lines going into the firewall and looks like directly into the heater core, but I've never seen one that did.
Thanks for the info. Just want to know what to look for, I'm assuming the core is stopped but want to make sure there isn't a valve that could be messed up.
Old Nov 22, 2008 | 08:39 PM
fmc400's Avatar
fmc400
MSEE
Since no one else has chimed in, I'll throw in my 2 cents. I'm about 95% sure that non-AC trucks don't have the heater valve. I hope that helps...somewhat. But I do know for sure that there is no such valve internal to the heater core - so if you can't see it from the engine bay, it's not there. If your heater isn't blowing very warm; how do the heater hoses feel? Are they as hot as the upper radiator hose when warmed up? These things need to be backflushed after a while.
Old Nov 22, 2008 | 09:21 PM
Bgasrickshaw's Avatar
Bgasrickshaw
I think you are right fmc400 the coolant flow is constant through the core and the temperature is controlled by opening or closing a damper to regulate air flow through the core
Old Nov 22, 2008 | 10:59 PM
ramarado's Avatar
ramarado
Thanks guys, that is what I had pretty much decided so I'll try the back flush and see what happens.
