engine block heater
Old Jun 29, 2013 | 04:58 PM
30-06wade's Avatar
30-06wade
engine block heater
Hey brotherhood, I have another question for you all. so my truck I buy used but I love it 03 f250 lariat fx4 crew cab. and when I bought it the truck has the plug in for the heater for engine I want to know how can I check to see if it works and also does it just take a extension cord and that's all?
thanks for your help
Old Jun 29, 2013 | 05:52 PM
BrandonT71's Avatar
BrandonT71
yep, extension cord is all you need. If you a volt/ohm meter you could check the heater that way. Set meter to read ohms, place one lead on flat blade of plug, and the other lead on the other blade, you should get a reading, not sure what exactly
Old Jun 29, 2013 | 06:11 PM
BrandonT71's Avatar
BrandonT71
Did a little checking and calculated resistance (ohms) based of wattage spec for heater, you should be reading somewhere in the neighborhood of 14.5 ohms.
Old Jun 29, 2013 | 06:21 PM
JOHN2001's Avatar
JOHN2001
Just an FYI you now have enough post I believe to fill out a signature so you won't have to specify what you have everytime you start a new thread
Old Jun 29, 2013 | 09:17 PM
30-06wade's Avatar
30-06wade
roger, john I was looking into do that but couldn't figure it out and didn't want to ask to many silly question.
Old Jun 29, 2013 | 09:21 PM
Tugly's Avatar
Tugly
Up high on this page... on the left. "User CP". Then you can edit your signature.
Old Jun 29, 2013 | 09:25 PM
30-06wade's Avatar
30-06wade
thanks tugly and I just figured it out lmao I am not a computer savvy guy I am boots on the ground front line guy (outdoors)
Old Jun 29, 2013 | 09:27 PM
30-06wade's Avatar
30-06wade
oh and thanks Brandon for you info. I will go out there and do that now thanks I appreciate that, I also should have figured this question out on my own also.
Old Jun 29, 2013 | 09:40 PM
BrandonT71's Avatar
BrandonT71
Don't sweat it, that's what the Brotherhood is here for! The only stupid question is the one not asked. Some day you will be able to offer your advice to a newbie, not that I'm a expert, far from it.
David Fehir
Jan 22, 2016 05:25 PM
EricPero
18
Feb 12, 2013 06:08 AM
poordieselowner
Dec 8, 2008 09:01 PM
THE KING
17
Jan 17, 2007 06:16 PM
dlpinkc
Jan 8, 2004 10:28 PM
