Block Heater Trips GFI Circuit
Hi all, I have a 2000 F-350 (7.3) with the original block heater. About 2 years ago I replaced the plug since it stopped working. I haven't tested the ohms on the plug, but I was wondering if it trips the GFI (I tried 2 separate circuits) does this indicate a bad heater or should I try replacing the plug again?
Thanks,
Eric
Thanks,
Eric
Thanks,
Eric
Thanks,
Eric
As far as element resistance (hot to neutral) for a 1KW heater which I believe is what ours are rated you should see around 14.4 ohms.
Note that a wet connection point will also trip a gfci
If it trips the GFI, you have 1 of the 3 is at fault. First just plug in the ext cord, if that doesn't trip the breaker than plug just the cord from your truck with the heater unplug at the block. If that doesn't trip the GFI, than more than likely the heater is partially shorted out. Much like the electric element in your house water heater, they will sometimes get a hot spot and split the side of the element and some of the electric current goes somewhere else and that is what causes the GFI to trip. The GFI measures the amount of current out and back, if it senses any difference it trips. HTH's
Thanks,
Eric
Thanks,
Eric
I pulled my heater cord totally out. Cleaned all metal with wire brush. I then checked for even the most minute kinks or marks on the entire cord. Low and behold, I pulled back and cut the insulation at the "kink" and 2 of the 3 wires were bare or close to it!!!! Connected them with wire nuts (cheap I know but it should get me through this winter), electric taped and sealed it all back up. Haven't tripped the circuit yet (knock on wood)... Hopefully this'll help OP out!!!
something else to keep in mind:
The way my house is wired all the GFI circuts in the house go to one breaker.One outlet in each of 2 bathrooms, 2 outdoor outlets and 2 in the kitchen. So.....if my wife fires up her hair dryer and hair straightener...it is cold enough for the dogs water bucket thermostat to kick on and my truck is plugged in that poor 20 AMP gfi breaker dosen't have a chance.
Is there anything else plugged in to your GFI that might be overloading it?
They both fit the same and use the same heater plug. Either one will work. The 1500W will heat up the fluid faster and use more energy (cost more) doing so.
Assume you have the 1500W heater. If you are paying $.25/Kwh, then you will be paying about $.375 per hour x the number of hours you have it plugged in.
Assume you have the 1000W heater. If you are paying $.25/Kwh, then you will be paying $.25 per hour x the number of hours you have it plugged in.
How many hours you have it plugged in makes a BIG difference.
Mine tripped GFCI and appeared to 'work' - but looked like this:
This fixed it right up!!!
I didn't know there was a 1500watt option. The only disadvantages I can think of is needing a dedicated circuit, larger ext. cord and heavy-duty timer to run it.
Kind of related - here's my Marinco mod:
I 'fixed' the cover popping open problem by installing an injector o-ring on it:
I bought a new cord at the IH heavy truck dealer for just under $30. Ford wanted $120, I think. You can buy a replacement heater and cord (both) for $60 from an auto parts store, and just use the cord, if you have no handy IH dealer.
The IH replacement cord is nicely made and has a better end-fitting (screw-down) than the crummy steel clip that Ford used, which cuts into the rubber. I would not risk using wire-nuts on a block heater cord, given the occasional engine fires, etc. that can happen with high-current heater cords plugged into trucks.
