6.0 no start....
Old Jun 26, 2013 | 08:05 AM
gbrmotorsports's Avatar
gbrmotorsports
6.0 no start....
Yesterday it started acting up and i thought it was a bad fan clutch, power was there, turbo acted normal according to the boost gauge, she was shifting fine but it had a loud fan sound. After she was sitting for awhile I fired her up to see if I could diagnose what was up and the sound was gone, so I took her around the block and it came back. Well after she sat for the night now it wont fire. It cranks and pops once like she wants to start but no go. and I could see everytime it popped that there was smoke coming out of the turbo...... Did I blow the turbo? Im at a loss here and appreciate any help.
Old Jun 26, 2013 | 09:00 AM
mustang_309's Avatar
mustang_309
Do you have any gauges that read live data like scan gauge II or one of the smartphone apps like Dashboss for IOS devices or torque for android? They are absolutely necessary in diagnosing these trucks. Do you have any DTC's present? You can have DTC's pending even without a check engine light. You need to check your FICM main volts if you don't have gauges then you can use a DVM to check the FICM main volts which need to be over 45, here is the link to the FICM test procedure from the tech folder, https://www.ford-trucks.com/forums/8...procedure.html
Old Jun 26, 2013 | 02:18 PM
BLADE35's Avatar
BLADE35
that fan can cause a No-Start
Old Jun 27, 2013 | 08:44 AM
gbrmotorsports
That's what I wanted to hear! I ordered a fan clutch just to try it before its off to the shop.
Old Jun 27, 2013 | 08:55 AM
mustang_309
Just try unplugging the clutch fan and see if it will start.
Old Jun 27, 2013 | 06:19 PM
cheezit's Avatar
cheezit
check the fuse to the fan as well.
f2-22 iirc
Old Jun 27, 2013 | 08:19 PM
JUGERNAUT's Avatar
JUGERNAUT
Yep it sure can blade if vref on the fan circuit shorts the vref for rest of truck is gone this makes no start.
Old Jun 28, 2013 | 12:22 AM
BLADE35's Avatar
BLADE35
Maybe he could probe it at pin #6 for Power at the Fan Plug
Maybe better test for power at PCM pin#46
Maybe a Fan SS/RPM Check
Would it go Slower/Faster if Lost Fan Power??
Old Jun 28, 2013 | 12:25 AM
BLADE35's Avatar
BLADE35
Maybe I should have said "Could Cause"
Alittle more Diagnostic would have Helped or Did you???
Cheryldale
Mar 10, 2019 08:09 AM
mlouritt
19
Apr 18, 2011 11:29 PM
Jammer151
May 11, 2007 07:23 PM
JAMESR
Mar 7, 2006 11:22 PM
jbbrandon
Feb 11, 2006 10:17 PM
