PLEASE HELP!!!!!
Old Jun 23, 2013 | 10:54 AM
FastTimes10's Avatar
FastTimes10
PLEASE HELP!!!!!
Im having trouble with my 6.0 on start up when cold...Before cranking over i let the glow plugs turn on then i crank the truck, it turns on but for a bit it coughs and throws out black smoke like theres raw fuel then as it gets hot it stops and runs perfectly fine...On my edge programmer its throwing codes for each cylinder saying "Injector Circuit Low"
Old Jun 23, 2013 | 11:01 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You'll need to check your FICM volts at KOEO and while cranking. I'm guessing your FICM is toast or at the very least on it's way out.
A redneck way to also test the FICM is to use a good hair dryer or heat gun and heat up the FICM before starting and seeing if that helps with the cold start running.
Josh
Old Jun 23, 2013 | 11:08 AM
FastTimes10
Lol I really appreciate it and I will try that
Old Jun 23, 2013 | 11:49 AM
mustang_309's Avatar
mustang_309
If it's throwing all injector circuits low the FICM is toast. Agree with Josh.
Old Jun 23, 2013 | 12:18 PM
FastTimes10
Sweet thanks so much so ill be purchasing a ficm... Any suggestions where I should get one from Programmed already
Old Jun 23, 2013 | 12:25 PM
bismic's Avatar
bismic
I would check the connectors first.
Also, having your unit repaired at FICMrepair.com is WAY better than buying a new one (unless you don't mind spending the money and buy BPD's re-engineered FICM).
Old Jun 23, 2013 | 05:15 PM
FastTimes10
So I can take it out and send it to get rebuilt
Old Jun 23, 2013 | 05:18 PM
mustang_309
Yepper, a lot of us on here have done just that.
Old Jun 23, 2013 | 05:20 PM
FastTimes10
And the problem was gone
Old Jun 23, 2013 | 06:10 PM
wrongway01's Avatar
wrongway01
KOEO voltage should be no less than 47 volts. If you have 47 or more volts on that test watch FICM voltage as you try and start the engine. If it dips below 47 volts replace it. Also on your scanner you will have all 8 cylinder codes for low voltage. Ford offers a "half shell" FICM for a lot less than a complete one for about half the price. And the half shell doesn't need programming.
Old Jun 23, 2013 | 06:33 PM
Bullitt390's Avatar
Bullitt390
No less than 45 volts at any time FYI
Josh
Old Jun 23, 2013 | 07:48 PM
jswartz84's Avatar
jswartz84
Have you tested the ficm yet? I would definitely test before repair/replacing.
Old Jun 23, 2013 | 09:06 PM
wrongway01's Avatar
wrongway01
Josh
47 is as low as I'll go with good batteries and alternator. But you can do whatever works best for you.
Old Jun 23, 2013 | 09:18 PM
Bullitt390's Avatar
Bullitt390
I suppose if you know better than Ford: TSB 10-12-6
https://www.ford-trucks.com/forums/9...10-12-6-a.html
I'm not sure if ED would even repair a FICM that shows greater than 45 volts.
Josh
Old Jun 23, 2013 | 09:34 PM
bismic's Avatar
bismic
Ed will PROACTIVELY make all the necessary upgrades and perform the required resoldering - even on FICMs that are supposedly working fine.
It is a nice reliability upgrade.
