painting dashboard
Old Jun 21, 2013 | 06:53 PM
ItsAFord55's Avatar
ItsAFord55
painting dashboard
Im in the middle of swapping out my dash and i was just wondering has anyone ever had any luck with painting plastic interior parts and not having the sun complety destory the pant? if so what did you use and how did you?
Old Jun 21, 2013 | 07:38 PM
SideWinder4.9l's Avatar
SideWinder4.9l
I've painted a lot of stuff with LMC Truck's Colorbond plastic paint.
The key to a good paintjob is in the prep work.
Started off by cleaning the dash with a degreaser/foaming cleaner.
Plastic razorblades are a lifesaver!
After a good rinsing, and a final wipe down... I sprayed it down with adhesion promoter (Duplicolor brand)
Then started spraying the dash (Note that it was just the shell)
At this point, I had 4 coats of Adhesion Promoter, and 8 coats of paint.
Gave it a final wipe down after 24 hrs of curing, to remove lint/dust, and sprayed it with 5 coats of clear coating.
It's been in the truck since april 15th of this year with 0 issues.
Then again, I'm extremely easy around it.
Old Jun 21, 2013 | 07:41 PM
Jarryd's Avatar
Jarryd
I've been thinking about doing this with mine too. I like my blue interior, but its hard to take for extended periods of time and I really like the light gray interior offered in these trucks.
Old Jun 21, 2013 | 07:44 PM
SideWinder4.9l
'Just find a donor truck and get the complete interior.
1992-1993 Grey is a different shade than the 1994+...
Also, the piece of interior trim that holds the headliner up in the front is different from 1992-93 than 1994+.
1992-93 has 3 holes and the 1994+ has 4.
Old Jun 21, 2013 | 09:10 PM
Jarryd's Avatar
Jarryd
Yea a donor would be easier. I'd like to find a donor with 40/20/40 seats too or maybe just swap in seats from a newer truck and fab brackets.
Old Jun 21, 2013 | 11:16 PM
90'F150's Avatar
90'F150
Did they make a black interior for the 87-91 trucks? I'm not too keen on the blue I'd rather have black
Old Jun 22, 2013 | 10:48 AM
jimbo285's Avatar
jimbo285
How much work is it to get the dash out of our trucks? I didn't think I would be able to get to all the bolts. How much stuff has to be removed?
Old Jun 22, 2013 | 10:55 AM
SideWinder4.9l
There's 5? up on top where the defrost vents are, and about 8-10 along the bottom. After you remove the instrument cluster bezel, and whatnot it pretty much falls out for ya.
I can remove one in less than an hour now
Old Jun 22, 2013 | 11:20 AM
Eddiec1564's Avatar
Eddiec1564
I painted my 89 F250 dash last month. I used the Krylon Fusion paint for plastic. I did mine in the truck, just mask off areas not to be painted. Removed vents and anything else I did not want to paint. I used Simple Green to clean off the dash, then rinse with water, Let it dry then painted.
And after:
Here's the rear cab trim. I'm swapping out for a 92 as it has a speaker that mounts in it. Had to do a few mods to the 92 trim to fit the seat belt mounts. Still have to mod the cab it self, stupid bracket in the way of the speaker.
So far its holding up really good.
Old Jun 22, 2013 | 11:25 AM
eagle275's Avatar
eagle275
Looking for 40/20/40 seats also. Aftermarkets seats like that are between $700 and up.
Old Jun 22, 2013 | 12:46 PM
SideWinder4.9l
And after:
Looks good, but when you take it out, you can get the paint into every nook, cranny and hidey hole.
I actually removed the defrost vents, cleaned them, and painted/clear coated them also.
It looks BRAND new now.
Old Jun 22, 2013 | 12:56 PM
Eddiec1564's Avatar
Eddiec1564
I should of done that 5 years ago when I had it totaly apart fixing a firewall leak. Just didn't think of it back then.
Old Jun 22, 2013 | 01:05 PM
Jarryd's Avatar
Jarryd
Now I want to do mine but its my door panels that really look bad, and my carpet/seats. I just want to replace everything.
Old Jun 22, 2013 | 10:28 PM
dixie460's Avatar
dixie460
Where was your firewall leak? I have one directly behind my gauge panel. Am waiting for a nice weekend to pull the entire dash out and fix the leak.
Old Jun 23, 2013 | 08:27 AM
Eddiec1564's Avatar
Eddiec1564
It was the firewall to cowl seam that was leaking. That old seam sealer cracked and leaked. I took the whole dash out and resealed the cowl area(outside and inside), and painted bed liner paint on the firewall. No more leaks execpt where the brake booster mounts and the AC box mounts. Those foam gaskets must of rotted now...
I have some threads about this about 4 to 5 years ago here.
a truck named effy
16
Nov 7, 2024 07:07 PM
55RoundTwo
Apr 3, 2019 02:59 AM
Cedarghost
194
Apr 13, 2017 10:03 AM
SideWinder4.9l
Apr 6, 2013 08:24 PM
ebodell
21
Apr 20, 2011 07:22 PM
