only 300 psi after a long drive, won't start
Old Jun 20, 2013 | 10:49 AM
Spectramac's Avatar
Spectramac
I have this 05 with a high pressure issue. If you drive it for a half hour or more it only builds 300 pounds after a 10 minute soak and refuses to start. Must be a pretty small leak, cuz it always starts cold and will sometimes start hot after a looong crank. I've checked for a bad STC fitting and it's already been replaced. I'll be pulling the covers today to look around the injectors.
Old Jun 20, 2013 | 12:08 PM
mustang_309's Avatar
mustang_309
Check if your truck has the updated standpipes and dummy plugs, if it doesn't that is probably the source of your leak. The way you can tell is the original standpipes and dummy plugs take a 10MM hex bit and the updated ones take a 12MM.
Old Jun 20, 2013 | 12:49 PM
big inch's Avatar
big inch
My money would be on dummy plugs.
Old Jun 20, 2013 | 02:50 PM
wrongway01's Avatar
wrongway01
Dummy plugs get my vote too.
Old Jun 20, 2013 | 05:52 PM
Spectramac's Avatar
Spectramac
Well, you guys called it. Pulled the right cover and took both plugs out. The lower ring on the dummy was shot. The other side can't look much better...
Old Jun 20, 2013 | 10:30 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Yep all the tell tale signs of the Dummy Plugs and Stand pipes failing. It'll take some time, but good you know which side is causing the proble, git'r done.
F250.stroked
Dec 7, 2017 12:38 PM
Iaff113
Oct 19, 2014 09:39 AM
ballbandit
Feb 22, 2013 08:00 PM
f350ranchand
Jan 30, 2012 09:51 PM
reds250
Nov 25, 2011 06:45 PM
