Starting issues
Old Feb 22, 2013 | 06:19 PM
ballbandit's Avatar
ballbandit
Starting issues
05 6.0 208,000 miles. You start it and you can drive anywhere. You shut it off and it wont fire back until next day. Last night i started it cold and let it run maybe a minute, shut it off and tried to restart. Was a no go. When it does start icp is around 700 and duty cycles 26. When it doesnt start icp is 380 and.duty goes to 85%. Tried ipr for the heck of it. No luck. Dont understand how when.it starts you can drive anywhere until you shut it off. Guess ill start with stc. Unless somebody has better idea thanks
Old Feb 22, 2013 | 06:40 PM
BLADE35's Avatar
BLADE35
you have a HPO Leak
Replace STC Fitting and Standpipes and Dummey Plugs are the Most common for 05+ to go out
Hot Oil Viscosity is thinner so you cant build the Required amount of press to start again once oil is Hot
Then it cools and has a Thicker Viscosity so it can build the required Press to start
Old Feb 22, 2013 | 07:29 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Must be a good sized leak that only 1 minute run time causes a no start.
Josh
Old Feb 22, 2013 | 08:00 PM
m-chan68's Avatar
m-chan68
STC fitting.
gerryrandolph
Sep 10, 2012 09:41 PM
jmorgan2622
Feb 19, 2012 08:24 PM
JerrywallaceII
Sep 27, 2011 07:06 AM
larchy
Jun 24, 2010 01:55 AM
