Bent Push Rods
Old Jun 19, 2013 | 12:39 PM
bchnut's Avatar
bchnut
Bent Push Rods
My truck threw a #3 contribution fault months ago and I have been throwing parts at it since. Ficm rebuild, Injector and the latest new push rods which where slightly bent on #3 cylinder. I did notice when I replaced the push rod that the new one was shorter than the original. when I asked the Ford guy he said that it's the way they make them now. I am at the point were I just want to get rid of the truck (financial reasons) other wise I love the truck. I just don't know were to proceed in the repair process anymore without going to a professional. Any clue ?
Old Jun 19, 2013 | 03:54 PM
m-chan68's Avatar
m-chan68
This is a very interesting question posted. Hopefully the quote from another tech, off another forum I frequent may shed some light onto the ones where roller lifters are failing. Here is the quoted text:
Originally Posted by matt
I'm being told by a fairly reliable source (an engine rebuilder) that OEM 6.0 pushrods and the current part number 8C3Z-6565-B are different lengths, namely the the new pushrod is .050" shorter. I am aware it is also a 6.4 pushrod and the 6.0 number crosses over to the 6.4 number.
I was also told this is a reason for 6.0 lifter failure among other things. OEM 6.0 pushrods are too long and it causes the lifter to bottom out internally.
The portion of the quote highlighted in bold red should be considered very interesting information to ponder.
Old Jun 19, 2013 | 04:04 PM
MC5C's Avatar
MC5C
As soon as I read that I thought "deck the head a tad, valves move up, little bit valve job, valves move up, and all of a sudden the push rod is too long when it worked before". When I was building race engines one thing we often had to do was custom length push rods.
Brian
Old Jun 19, 2013 | 04:41 PM
Yahiko's Avatar
Yahiko
If someone had the time and tools it would be easy to check
the clearances and then take the spec for the lifters and cam
to get an answer. Instead of a guess. Granted it an educated guess
but still a guess.
The question boils down to how much head room do the lifters have
in there internal travel. With Ford's fix of .050" less rod I think
that is what they are thinking. It would be nice to know for sure.
That way if you do a valve job then you know that you have to
use the new shorter rods.
The more I see things like this the more I wished I had a engine
sitting around to play with.
Sean
Old Jun 19, 2013 | 05:26 PM
npccpartsman's Avatar
npccpartsman
I think this is very interesting information to know and some I've been looking for. With as many sets of decked heads (even from Ford) as there are running around this may be Godsend for me and a lot of other folks.
Old Jun 19, 2013 | 05:38 PM
bchnut's Avatar
bchnut
Ok to add to my misery I just did a pressure test on my coolant system (3/8 hose to degas bottle to gauge in cab) ...18-20lbs pressure. And I was flat out leaning on it! The bitch is it runs like a top at 80mph! Confused! I guess some head work and push rods are in the mix.
Old Jun 19, 2013 | 06:29 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Back to basics for you. EGR valve /intake manifold dry?
Old Jun 20, 2013 | 04:13 AM
bchnut's Avatar
bchnut
I just put a Egr Cooler, Oil cooler, Cleaned turbo and rebuilt FICM on it less than 6 months ago.
john jamieson
Oct 2, 2021 12:38 PM
Mcrafty1
Jan 31, 2014 06:53 PM
M04
13
Nov 10, 2004 08:04 PM
BBIGG_CCHILL
Mar 23, 2003 09:22 PM
Ford Tough
Jun 5, 2002 03:43 AM
