Bent push rods
Old Jun 3, 2002 | 09:52 PM
Ford Tough's Avatar
Ford Tough
Post Bent push rods
Just installed a remanufactured 351M in a 1981 F-150. This new engine is bending the exhaust push rod on the #4 piston on the lefthand side. I'm guess a couple of things.
1. Valve sticking to the head
2. Bad lifter (any way of testing it?)
3. Bad geometry of the rocker arm?
4. Cam problem?
5. Too tight of an adjustment?
Here is the issue. Engine runs fine. Let it sit one day, crank it the next day and the engine bends the push rod!! It's done it twice already. Replaced the rod and engine cranks up and runs fine? What is happening after the engine sits overnight?
Sure would hate to pull the engine!
Old Jun 4, 2002 | 11:58 AM
beartracks's Avatar
beartracks
Bent push rods
Well the lifters have no adjustment. If they over machined it you might bottom out a lifter. Different length push rods and shims for under the pedestals are available.
I could be that the push rod is sitting on the lip of that particulay lifter instead of the seat.
Bear Tracks
Old Jun 4, 2002 | 05:04 PM
Ford Tough's Avatar
Ford Tough
Post Bent push rods
Thanks for the info. I'll keep you updated on any progress.
Old Jun 5, 2002 | 03:43 AM
Superdave's Avatar
Superdave
Bent push rods
13
Jun 25, 2016 08:33 AM
webslinger67
Oct 14, 2013 03:47 PM
rolape2
May 15, 2011 10:06 AM
rickatic
Oct 28, 2009 06:42 PM
Shelby Sam
Apr 10, 2004 01:10 PM
