Junk Yard Browsing
Good book for a rebuilder, some good reference material for sorting out the various parts and peices of the FE series engines; casting #'s listed for the blocks after `65 need to be taken with a grain of salt, however. Ford pretty much used the same external molds for various cores after then, except for the 427's.
2) Pat Ganahl's "Ford Performance", ISBN 1-884089-27-5.
Another good reference book, covers Ford's modern V8's; Small Block, 385 series BB (429-460), FE series BB, and 351C/400 series.
As for the 390 in the 4x4 not likely, but possible. They had warranty issues with the torque of the 390 breaking things on the 4x4's, so they went to 360's only, but that could have been a transplant. Same with the Bronco, they quit using the FE's in `76, and were in trucks only past `71 (maybe `72 not 100% sure)
As for identifying the different FE's, the quickest way is the stroke (assuming the engine is still intact, or in the vehicle).
Put the #1 piston at TDC, and use a small dowel/rod through the spark plug hole, straight down as much as possible. Mark it where it hits the lip of the opening.
Now do the same thing in the #4 cylinder, (dont turn the engine!) trying to make sure the dowel hits the same part of the piston (many were dished and this will throw off measurement). Measure the difference.
3.50 inches is a 352 or 360 (352 discontinued after `67)
3.78 inches is a 390 (or a 427 if you're REALLY lucky!)
3.98 inches is a 410 or 428 (410 was `66-`67 Merc only)
There was also a 406 which used the 390's stroke with the 428 size bore (4.13) But for the most part what you will find in the `yards, are 360's (truck only) or 390's.
Here's some good reference for 428CJ identification:
428CJ site
Head casting #'s, crank #'s, rod's etc, can help to pinpoint what you have.
Whew, long winded, but hopefully this helps some. Welcome to FTE and don't be afraid to ask questions!
Thanks for the update, glad to hear you found some books as well! The trans for a 360/390 will only fit the FE family of engines. The 429/460 falls in the "385" series of engines, I think their bell housing is only compatable with a 351C, but I may be mistaken. Your best bet will be to take a look at the back of the motors or the tranny. The key point with them is on the tranny, the distance between the two top mounting bolts. I think they are narrower than on the small block 289/302/351 engine.
Happy hunting! --MG
