Cold A/C mod using Excursion heater valve question...
Old Jun 16, 2013 | 03:55 PM
Bonanza35's Avatar
Bonanza35
That's what I thought too. But I like the outside air, so if it cools that down that's the way I'm going to go. Good luck guys, I know you'll like the improvement either way.
Chet
Old Jun 16, 2013 | 04:24 PM
cj45lc's Avatar
cj45lc
Originally Posted by cjgray1974
I believe it flows from the pump to the heater core, But I'm not 100% sure. Like David said, which ever one you do will stop the flow.
One way to check is get truck to operating temp, then feel the hoses and see which is warmer.
Just the opposite, water flows from the pass side head to core then to water pump
Old Jun 16, 2013 | 07:23 PM
fordtruck661's Avatar
fordtruck661
This is the one I got Buy Factory Air Heater Control Valve 74809 at Advance Auto Parts
It allows the coolant to keep circulating.
Old Jun 16, 2013 | 09:26 PM
tappit01's Avatar
tappit01
i hope it works out for you but, did you by chance notice all the bad reviews it got on their site. i'd keep my eye on it.
Old Jun 16, 2013 | 09:43 PM
fordtruck661
I did not notice the reviews but have not had any problems yet and seems to be working.
Old Jun 17, 2013 | 10:06 AM
cjgray1974's Avatar
cjgray1974
Thanks for setting us straight.
Old Jun 18, 2013 | 09:43 AM
ztodd377's Avatar
ztodd377
Will it cause any problems have manual shut off valves in the heater core hoses since the coolant is circulating? It seems to me that if its supposed to flow from the head through the core to the water pump and u shut that off, what's the alternate route for coolant to circulate?
Old Jun 18, 2013 | 09:04 PM
dn29626's Avatar
dn29626
From the PaysonPsd library.
Colder AC Photos by PaysonPsd | Photobucket
Old Jun 18, 2013 | 10:18 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
There is a bit of an issue. It still circulates but if I recall one end of one head doesn't get well circulated.
pwstroker69
15
Oct 20, 2015 12:52 PM
sleep_deprived129
Dec 1, 2011 09:41 PM
rockyrider
20
May 19, 2005 09:52 PM
Frank Kistner Sr.
Aerostar
13
Feb 3, 2005 03:32 PM
dbc2004
Jun 24, 2004 06:14 PM
