If the threads in the head are damaged/stretched you could try Timesert. I used it on a Mercedes 603 head where the damper bolt had stripped out, worked great. A bit pricey but far superior to a helicoil.
I hope this isn't a stupid question, but were your bolt holes cleaned with a solvent first? My understanding is thread lock won't work on oily surfaces. Hope this wasn't mentioned before, I didn't follow the injector thread of yours.
It's a valid question, but yes... I was as **** about cleaning the threads as I was about cleaning for the cup replacement. That was part of the frustration level.
The thread locker package implies that Red is the superhuman version of thread lockers. But, Blue sometimes doesn't cut it. I doubt you'd have any issues with Red in those holes. I've had Red be really tight, but I've never had to use heat to remove a Red-held bolt.
You might consider buying brand-new hold down bolts, too, as I have had bolts on my tractor that simply were worn to where they would not stay tight no matter what. I don't think your star washer idea is great, but it's not the worst idea, either.
How about installing studs in the heads and then using two nuts (jammed against each other) to hold it tight? (There may not be room for this, and you risk damage if you lose a nut off the end...) When bolts don't cut it in the 4x4 world (suspension/axle stuff), people usually resort to studs.
Just some thoughts.
Red has five times the holding power of the blue. This could feasibly spin the 6mm-diameter bolt right off. I'm not brave enough to go there. The beauty of the tack-weld is breaking the tack is by way of force on the head, not the threads.
That's a great suggestion... but I'm on my third set of bolts now.
I can go one better - lock-nut under the hold-down bracket (it's only the lower bolts with the problem). I need to look at photos again to see if a metric wiz-nut can fit under the bracket. Very cool concept that frustration level prevented me from thinking of that before.
Rich I had to pop the VCs quite a few times dealing with my new injectors, but it does not come close to what you have had to do. I know I was very frustrated with my situation but cannot imagine what I would be thinking or doing if I was in your shoes.
Anyhow I am not a Mech Engineer, but I was also thinking studs. The nut under the hold down bracket is not a bad idea eaither. I think I would have to agree that the threads have to be damaged eventhough they have been tested. You would have to be pretty brave to tap them bigger, but then you have to find bigger bolts and hope they fit through the bracket. Good luck.
Honestly, I think you a little crazy to consider a tack weld instead of Red Loctite. 1) I wouldn't want spatter anywhere under my VC's!! 2) The amount of heat needed for a tack can change the bolt grade. It maybe slight but there.
I've never had my VC's off before, so I don't know exactly what it looks like under there, but the stud idea with a nylock or lock nut sounds like the better option.
Tugly, I didn't read the whole thread but was thinking that drilled head bolts would work to put safety wire through. That would stop any backing out and not interfere with operation. Now the question is, where to get those type bolts with the heads drilled and would it be worth the price. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
You could try mushrooming the threads of the bolts in a vice ( a little), it would throw off the torque spec but the hole is already stretched so that's not a concern.
Studs - then I'd need to find a nut that fits the taper in a hold-down bracket... and what's to prevent one of two pieces from failing to hold (stud and nut)?
You think me a little crazy? Apparently you missed my comment on how spending a lot of time, money, and effort to lift the VCs over a dozen times has triggered a monkey poopfest between my ears... and I no longer trust my thinking. I'm not shooting any ideas down, I'm just thinking each one through - pros and possible cons.
If I TIG it, there shouldn't be any splatter or slag (allegedly)
Changing the grade of the bolt might be a more attractive option than changing the grade of the whole vehicle... but you make a valid point.
Yes your correct. TIG weld theoretically no spatter, BUT you will put more heat in the bolt trying to get it up to melting temp vs a MIG to just stick the two metals together.
Honestly, you have me a little worried about trying SS injectors and being in the same boat...lol.
...Notice anything between the hold-down bolts?[/SIZE][/FONT][/COLOR]
Looks like a perfect shot to me. Straight across...forward injector to the rear injector. Because of the way the injector clamp works...as long as the lower bolts remain tight, the upper bolts will always be in tension and shouldn't work loose. You could even use the red loctite on the upper bolts since they bottom out in the blind hole and in theory you don't need to remove those hardly ever.
I must be missing something in that photo. Safety wire ready bolts should work. All your looking to do is stop the loosing rotation by using the safety wire.
It can't happen to you... I had this luck custom-tuned for me. Besides, it would have happened to me on splits.
Possibly spring rub.
Rocker arms for sure. They rock down on to push the valve springs.
..Rocker arms for sure. They rock down on to push the valve springs...
Good point. I didn't think of that.
If you are adventurous....then you can have the injector clamps machined for a set screw. A sharp point set screw might dig into the tapered portion of the screw...
