p1280 code
Old Jun 14, 2013 | 03:16 PM
A-Z Racing's Avatar
A-Z Racing
p1280 code
I'm not sure if this could have cause this code to come up or the sensor is bad or what. I have a 2000 f-250 with 7.3, 281,000 miles. I have always used standard Rotella oil and last week installed Rotella synthetic for the first time and now i have a service engine light on. My buddy's code reader shows a p1280 code low pressure. The truck is running fine. Should i start with changing the ICP first and see if that clears it up?
Old Jun 14, 2013 | 03:45 PM
Tugly's Avatar
Tugly
You probably just got some air in the line. Clear the codes and see if it returns. If it does, the Injector Control Pressure sensors last about 12-13 years and 275K miles. I'm clowning around, but mine just died at those numbers.
Old Jun 14, 2013 | 05:50 PM
A-Z Racing's Avatar
A-Z Racing
Cleared code and it came back instantly.
Old Jun 15, 2013 | 05:38 AM
Tugly's Avatar
Tugly
Clean the connections on the ICP with electrical contact cleaner and see if that helps with the code.
Old Jun 15, 2013 | 07:08 AM
F350-6's Avatar
F350-6
What code reader is he using? When you cleared the code and it came back, did the CEL come back on? Might just be a code reader issue.
Otherwise check the wiring to the ICP sensor. 1280 is what you get if you unplug the sensor while it's running.
Old Jun 15, 2013 | 08:45 PM
A-Z Racing's Avatar
A-Z Racing
He used a snap on reader, his best of the three he owns. I checked the wiring today it was attached and from what i can see they look ok. I ordered a new motorcraft sensor from Riffraff last night. I'm sure the old one is ready for a update. I will see what that does. Is there any chance the synthetic oil viscosity had an affect on the sensor? I'll clean the contacts tomorrow and see what that does.
Old Jun 15, 2013 | 10:07 PM
F350-6's Avatar
F350-6
Pressure is pressure. Synthetic isn't going to build any more or any less pressure than regular oil. It's just going to flow and wear different.
Now if the synthetic isn't properly rated, or if you added a bunch of oil additive, then it could be foaming and causing an issue, but if it's good diesel rated oil with no other additives in it, then it's not the oil.
Old Jun 16, 2013 | 07:27 AM
A-Z Racing's Avatar
A-Z Racing
Thanks for the reply. First time using Rotella synthetic and with my high mileage i thought it may have caused a issue.
Old Jun 16, 2013 | 07:47 AM
Crewcab Turbo's Avatar
Crewcab Turbo
I have 230k on my truck and I switch back and forth from synthetic to Dino oil every winter summer and I have no problems.
Old Jun 16, 2013 | 11:12 AM
F350-6's Avatar
F350-6
I switched over to Rotella synthetic for a while when I had a little over 300,000 miles on the truck. Local walmart started selling it for less money than the regular rotella oil so I made the switch. Ran it for 4 or 5 oil changes till they stopped carrying it and then switched back to the regular stuff.
No codes, no leaks, no troubles at all and it's been over 100k miles since I switched and switched back.
Old Jun 16, 2013 | 08:18 PM
A-Z Racing's Avatar
A-Z Racing
Ok, i will clean the connection tomorrow and change the sensor when it arrives.
sandyc
6.7L Power Stroke Diesel
May 30, 2018 12:21 PM
GwarForAll1021
2004 - 2008 F150
Jan 10, 2010 09:41 AM
y2kexc
18
Jul 29, 2005 08:04 PM
rmarion
1983 - 2012 Ranger & B-Series
Sep 19, 2004 07:51 PM
