Bad fuel pump???
Old Jun 13, 2013 | 08:23 PM
ncycenas's Avatar
ncycenas
Bad fuel pump???
I have a 91 f150 4.9 straight 6 and wenever i start it it will sometimes die. ( more like stall) and when im at a stop light and try to go it will sometimes do the same thing. Any ideas on whats wrong. Bad fuel pump, fuel filter, fuel line? Any help would be great
Old Jun 13, 2013 | 08:35 PM
JWC 3's Avatar
JWC 3
Have you cleaned your throttle body and IAC ? Ck your tps also . It is always good to keep your fuel filter changed on a regular basis . A pressure test will tell you about the pump .
Old Jun 13, 2013 | 08:37 PM
RedDragon777's Avatar
RedDragon777
Easy way to tell is swap the fuel filter first then try and trace your fuel lines and make sure there are no kinks after that if it still happens then there is a good chance it is your pumps.
AFoster1025
Oct 25, 2010 05:48 PM
BobbySmith
34
Feb 13, 2009 05:52 PM
bigsteve-o
18
Apr 2, 2007 10:18 AM
mike L
Sep 1, 2004 04:23 PM
classicfordluvr
May 9, 2001 08:38 PM
