external fuel pump going bad????
Old Aug 25, 2004 | 06:43 PM
mike L's Avatar
mike L
Hi guys! I have a 87 f150 4.9 reg gas . My external fuel pump just started making a load winning noise that doesn't go away. When i start the truck it takes an extra few secs to start and it sputtered about five times today while driving. How can i tell if its that pump or the one in the tank? Do i have to do a fuel pressure test between the two pumps? thanks mike
Old Aug 26, 2004 | 04:51 PM
D Harry's Avatar
D Harry
I don't think you can hear the fuel pumps in the tanks. It's probably the frame mounted one.
Old Aug 26, 2004 | 08:40 PM
Beast12's Avatar
Beast12
Plugged fuel filter?
-Matt
Old Aug 26, 2004 | 09:35 PM
mike L's Avatar
mike L
bad pump or fuel filter???
I think I'll disconnect the fuel line between the fuel filter and engine and turn the key for ten sec's to see if i get 1/3 of a cup of fuel. I found this in my Haines manual. I replaced fuel filter last month, i think it was a Fram. i will change it to a better brand. Does a bad fuel filter make the pump work hard and makes noise??? Thanks any other ideas?
Old Aug 26, 2004 | 09:38 PM
FordPerf300's Avatar
FordPerf300
If you start hearing a loud whine from the pump it's probably on it's way. Do the test. You can defn hear an in tank pump go bad, one of mine is getting louder and acting up.
Old Aug 26, 2004 | 10:11 PM
mike L's Avatar
mike L
noisy intank pump
Thanks guys!!
Fordpef300 Are the intank fuel pumps about the same between 87 and a 93? I may of been misinformed by my ford dealer when he said i would not hear an intank fuel pump go bad. Does you tank still work? Can you hear it from inside the truck ? What does it sound like?
Beast12 i love your saying!! Smile .... it confuses people
Old Aug 26, 2004 | 11:20 PM
FordPerf300
The earlier trucks that used a high pressure pump was fords transitional period from carb to EFI. Still having pumps suited for carbs they were still used and the final pump boosted the fuel pressure up to the EFI's needs. Once the old style pumps were phased out, single in tank high pressure pumps were used, so no, the pumps are not the same. As for mine i can hear a whine from my front pump which i do not hear when i switch to the rear pump. It still works, sometimes they die quick, sometimes they live on whining away for a while.
Old Aug 26, 2004 | 11:32 PM
mike L's Avatar
mike L
Thanks, Is my in take pump low pressue with 4to 6 lbs?? Would mine make noise if its going badI have an 1987 F-150, 4.9, 2wd
Old Aug 26, 2004 | 11:44 PM
FordPerf300
it's hard to diagnoss without testing first..either of them could be going bad
Old Aug 27, 2004 | 12:52 AM
mike L's Avatar
mike L
is there a test for the intank pump? Do you need special tools.
thanks,
mike
Old Sep 1, 2004 | 04:23 PM
mike L's Avatar
mike L
Replaced winning external fuel pump its works!!
Replaced external fuel pump, no more noise and runs great. thanks guys!!
