do I need a fuel pump
Old Mar 31, 2007 | 09:55 PM
bigsteve-o's Avatar
bigsteve-o
Unhappy do I need a fuel pump
my 1986 f150 just wouldn't start after shutting it off when I got to where i was, I put a new fuel pump modgaler when I pull it out and jump it I can here the fuel pump turn on but it wont fire up, I put a little gas in the throttle body and it started, only for a second though, I didn't check the fuel presure, but could it be the fuel filter or fuel pump.
Old Mar 31, 2007 | 11:24 PM
phil6608's Avatar
phil6608
Welcome to FTE.
Sounds like a good place to start.Start with the filter.
Old Apr 1, 2007 | 07:49 AM
subford's Avatar
subford
Need a little more information on this one.
What is a "fuel pump modgaler"?
Maybe a "fuel pressure regulator"?
How many fuel tanks?
What size engine?
Is this a fuel-injected engine?
What are you jumping to get the fuel pump(s) to run?
Old Apr 1, 2007 | 08:41 AM
bigsteve-o's Avatar
bigsteve-o
Unhappy fuel problem
it is a 302 fuel injected the fuel modulator has been changed 3 times
Old Apr 1, 2007 | 08:53 AM
subford's Avatar
subford
What is a fuel modulator?
Old Apr 1, 2007 | 09:53 AM
quicklook2's Avatar
quicklook2
do you mean fuel pressure regulator?
Old Apr 1, 2007 | 10:33 AM
Bruce R Leech's Avatar
Bruce R Leech
dose that have a inertia switch to cut off the fuel? if so reset it
Old Apr 1, 2007 | 10:50 AM
quicklook2's Avatar
quicklook2
every fuel injected vehicle has an inertia switch.
Old Apr 1, 2007 | 12:14 PM
Bruce R Leech
I would reset it. it is worth a try. also before you go changing a bunch of parts pull the codes and get a presher gage and check to see what you have and where you have it. if the truck was running fine and you turned it off and it wont restart I dont think that will be the filter callusing that .
Old Apr 1, 2007 | 01:14 PM
bigsteve-o's Avatar
bigsteve-o
it's fuel injected, 302
Old Apr 1, 2007 | 01:56 PM
Modifiednut's Avatar
Modifiednut
You mean an "electronic" fuel injected 302?
Old Apr 1, 2007 | 06:07 PM
subford's Avatar
subford
I still want to know what you jumped to get the fuel pump(s) to run?
And what is a fuel modulator?
And how many fuel tanks do you have?
Old Apr 1, 2007 | 06:45 PM
quicklook2's Avatar
quicklook2
the inertia switch on an 89 is above the brake pedal.
Old Apr 1, 2007 | 06:54 PM
Bruce R Leech
maybe he is pulling our leg
Old Apr 1, 2007 | 07:39 PM
bigsteve-o's Avatar
bigsteve-o
1 gas tank, and there is a prsure regulater by the master cyclnder that I changed 3 times and I put a wire in there to get the fuel pump to kick on
