ac clutch replacement issues
Old Jun 12, 2013 | 11:42 AM
Prof2113's Avatar
Prof2113
I have a 1996 F150 with the 4.9.
Replaced the ac clutch. Shimmed to the .014-.033 specs. When I turn on the ac, the clutch spins on the front of the pulley surface. (Slipping, I assume). I am wondering if I should reduce the gap, or enlarge. I am assuming reduce. Current spacing is .024.
Thoughts?
Thank You!
Old Jun 12, 2013 | 01:10 PM
jas88's Avatar
jas88
Can you turn the clutch, and therefore the compressor, by hand? Are you sure it's not the magnetic coil that is at fault?
Old Jun 12, 2013 | 03:44 PM
Prof2113's Avatar
Prof2113
Replaced the pulley, clutch, bearing, and coil as a set. I can turn the compressor by hand.
Old Jun 12, 2013 | 06:30 PM
bashby's Avatar
bashby
What was the old one doing.. same thing? If you have battery voltage at the comp, backprobing, with it connected then you either have a bad clutch or more likely, the compressor is too hard to turn.
Old Jun 12, 2013 | 11:05 PM
Prof2113's Avatar
Prof2113
It appears the compressor is going out. Disconnected the field coil so I don't accidently turn it on. Now I'll be looking for a new compressor and all that other stuff to rebuild the system.
Thanks for your help!
Old Jun 13, 2013 | 12:48 AM
IowanStraight6's Avatar
IowanStraight6
Remember to pick up a new accumulator and orface tube if you replace the compressor
gtadim
Jul 6, 2019 06:06 PM
dmueller71
Sep 18, 2015 11:21 PM
joestratton1
Mar 9, 2009 09:17 AM
xtmsports
Aug 23, 2006 01:29 PM
spdjunke
Aug 8, 2005 09:56 AM
