Computer Chips & Tuners
Programmer vs. Diablo chip
Old Jun 9, 2003 | 06:28 PM
manstruck's Avatar
manstruck
I want to order a Diablo chip - but a programmer isn't much more money, if any at all. What are the benifits to getting a chip vs. a programmer?
I would like my truck to shift a little later because of the tires I put on.
I'm ready to get something, just want to get the right something.....
And I do plan on getting a bigger MAS Air Flow Censor - with this information, let have your opinion.
Ed
Old Jun 9, 2003 | 06:49 PM
FTE Ken's Avatar
FTE Ken
The Super Microtuner Advantages:
1. Diagnostic code reader
2. Plug and play operation
The Diablo Predator Advantages:
1. More programs than the Microtuner
2. Full text diagnostics
3. Custom shift modifications
4. Live sensor readouts
5. The ability to download custom tunes
6. The ability to update the device
Diablo Chip advantages
1. Switch on the fly between low and high HP settings. If you tow this is a big bonus. Whenever you see high EGTs you can switch down without having to slow down.
2. Ability to custom program for your needs
Old Jun 9, 2003 | 07:55 PM
manstruck's Avatar
manstruck
Is the Diablo Predator available for 2003 5.4? And how much is it?
Ed
Old Jun 9, 2003 | 08:07 PM
FTE Ken's Avatar
FTE Ken
My mistake. I overlooked your signature. The Predator is for the Powerstroke only.
Switching between hi/low doesn't matter much with a gas engine.
The advantages of the Diablo Delta chip in this case:
1. slighly more power
2. custom programming available (you cannot use the Microtuner with modifications other than intakes, exhausts and tire size chances).
Old Jun 9, 2003 | 08:43 PM
manstruck's Avatar
manstruck
ok...
You can set up the Diablo chip for my intake, Exhaust, and change the shift points (higher)?
Thats what Im looking for. Im not looking forward to turning it on and off(unless there is a good reason for it). And whats the deal with the higher octain programing? Do I have to run higher octain gas with the chip? Answer these and Ill order one tomorrow.
Ed
Old Jun 11, 2003 | 12:38 PM
FTE Ken's Avatar
FTE Ken
On a MAF vehicle the intake and exhaust have no impact on programming. Programming would be the same as stock.
Yes, we move the shift points (the more throttle the higher up). Higher octane is required so we can lean the fuel ratio and advance timing in order to gain horsepower and torque.
Old Jun 17, 2003 | 12:46 PM
Ren_44's Avatar
Ren_44
Are there plans to make a Diablo tuner in the future? do you have to use a chip to get the better mods. as far as overwriting the stock programming?
Old Jun 18, 2003 | 08:18 AM
FTE Ken's Avatar
FTE Ken
Yes, there are plans. It will cost the same as the diesel tuner. Its several months away. I can't speculate on whether it will allow modifications you'd normally get with a chip because it doesn't exist yet.
Smokefan420
2004 - 2008 F150
27
Jun 4, 2007 01:01 PM
donbs
May 6, 2006 08:52 AM
DeckedoutF150
17
Feb 19, 2004 03:51 PM
rcwoods
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Nov 20, 2003 08:52 PM
chadrock
16
May 23, 2001 07:22 PM
