white smoke
Old Jun 11, 2013 | 06:11 AM
rjrandy96's Avatar
rjrandy96
white smoke
I have a 7.3l idi, and when you rev it up past 2000 rpm it starts to billow white smoke and backfire. when i say backfire i mean it sounds like unburnt fuel is going into the headers and burning in there. The injectors were just replaced a year ago and have only a few thousand miles on them. I need to figure out whats wrong with this i need it running soon. thanks for the help
Old Jun 11, 2013 | 07:47 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
no water in fuel light? did you drain the bowl to take a look anyway?
Old Jun 11, 2013 | 01:56 PM
rjrandy96's Avatar
rjrandy96
I replaced the fuel filter and also tried draining it. I also bleed the lines of any air.
Old Jun 11, 2013 | 02:00 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Sounds like IP
Old Jun 11, 2013 | 10:02 PM
rjrandy96's Avatar
rjrandy96
thats what i figured. il only be able to come up with enough cash to do either injectors or Ip i just need help to see if theres any way for sure i can tell if the ip is bad?
Old Jun 11, 2013 | 11:45 PM
hairyboxnoogle
You can have it flow benched, but it will cost... best alternative is find a used one and see if it fixes your problem. Before that though, try filling the filter with ATF, run it into the pump and let it sit for a day or overnight.
Old Jun 12, 2013 | 06:39 AM
rjrandy96's Avatar
rjrandy96
alrite atf couldnt hurt. it just clean everything up real well. how much would a used one cost?
SolidCitizen94
Nov 20, 2013 09:14 AM
brickguy08
May 14, 2008 10:56 PM
ufd1802
Sep 29, 2006 10:30 PM
Hillbily72
Jul 29, 2005 10:12 AM
ford4x4offrd
Feb 18, 2001 08:41 PM
