Coolant Filter Change Interval
Old Jun 10, 2013 | 10:05 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
How often is everyone changing their filters?
Seems like I am going through them like crazy, about 1 per month if I do it based on mileage. I am on my 4th or 5th one, I assume I can step out the intervals at this point.
Old Jun 10, 2013 | 10:22 PM
mueckster's Avatar
mueckster
After the first couple of filters, I went to changing them annually. Around 15k miles. I added the filter several years ago when running conventional coolant. After another flush, and going to ELC, it doesn't catch much now. I always seem to have good return to the degas bottle. I'd monitor the return flow and change it only when needed.
Old Jun 10, 2013 | 10:28 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
15 months,300 hours or 150k whichever comes first.
penray need release.
oops.disregard if your running ELC.wrong section.
Old Jun 10, 2013 | 10:36 PM
mueckster's Avatar
mueckster
Even when running conventional coolant, precharged slow release filters can over charge the SCA's and cause waterpump failure. The SCA's need to be monitored when doing so.
Old Jun 11, 2013 | 12:17 AM
Kdr358's Avatar
Kdr358
I am curious as well since I installed mine. I read somewhere that the first filter should be changed within 3 months unless the flow stops, after to change it 2x a year.
Old Jun 11, 2013 | 12:46 AM
milehi_350's Avatar
milehi_350
I changed the first filter after 6k miles. It was still flowing pretty good but figured I'd change it any way. I cut it open and it wasn't very sandy at all.
When I made the switch to elc, I flushed the heck out of it...then I flushed some more.
Does your filter stop flowing, and that's when you change it?
Old Jun 11, 2013 | 12:59 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I've never checked flow. My phone logs mileage and tracks maintenance. I just order a new filter when it says its time, which right now is set to 5k miles, which seems like overkill. I'm thinking I could change the interval to 15k.
Old Jun 11, 2013 | 06:49 AM
lhud's Avatar
lhud
Once you change the filter the first two or three times the system should be very clean. After that if you are using a quality ELC there should be no reason for the filter to catch anything substantial in size. I now change mine once a year and cut it open to see if there is something in there to be concerned about. You can check the flow by putting your hand on the filter - if it is very hot, then flow must be good.
Old Jun 11, 2013 | 07:30 AM
grec-o-face's Avatar
grec-o-face
My first filter change had about 3000-ish miles on it... I literally poured sand out of the filter. I did my second change after another 4000-ish, again, sandy... but not nearly as bad. I'm on my third filter now. I'll run this one for a while before changing it - maybe 8-10k.
Old Jun 11, 2013 | 09:10 AM
Fat Diesel's Avatar
Fat Diesel
Holy cow! You guys are keeping the filter mfg in business. I changed my first one after I don't know how long, and the second one has been on there for years and at least 40k miles. You'll know when it's clogged when it no longer gets hot to the touch from coolant flow.
Old Jun 11, 2013 | 11:13 AM
SpringerPop's Avatar
SpringerPop
Preeeeee-cisely!
Andy hit that nail!
All else is gross over-kill. This is a BYPASS filter for the coolant!
Even if it clogs, and you don't notice it for a few months, so what!
Pop
Old Jun 11, 2013 | 12:04 PM
grec-o-face
Originally Posted by SpringerPop
Preeeeee-cisely!
Andy hit that nail!
Pop
Well then... I'm sold!! I guess I'll just put more money into my 'coffee fund'!
Old Jun 11, 2013 | 12:10 PM
clem1226's Avatar
clem1226
Same here, when it clogs it gets changed....and it hasn't clogged 3 years.
The last clog was due to an oil cooler oring failure.
Old Jun 11, 2013 | 07:33 PM
Pitcrw6's Avatar
Pitcrw6
The first 3 filters get changed every 3 months then once a year after that or longer if you dont drive it that much.
ROBBINthaHOOD
Jul 21, 2013 08:36 PM
kidoo
Oct 5, 2011 05:12 PM
Talyn
30
Aug 9, 2011 09:58 AM
dagren99
Jan 9, 2008 01:49 PM
dyoungen
Oct 20, 2007 04:27 PM
