Engine Shot Out Freeze Plug
Old Jun 10, 2013 | 01:15 PM
InfidelReaper's Avatar
InfidelReaper
Hey guys. Got a brand new 460 just dropped into my 69 F100. I started the cam break in, and 5 minutes in it shot out the driver side freeze plug that's behind the engine mount. Any idea what would cause this? I went and got one of the screw in type ones just so I could finish the break in, but it shot that one out too. Looking for suggestions on where to start looking for issues...
Old Jun 18, 2013 | 12:58 PM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Yikes, is this a rebuild or a crate motor? The hole for the plug may be loose, perhaps a oversized plug would work?
Obviously the cooling system runs under pressure, but what pressure radiator cap are you using? It may be stuck closed or higher pressure than the engine can handle. I would start with checking/replacing the cap. Do you have means of checking the cooling system pressure?
Old Jun 18, 2013 | 01:33 PM
InfidelReaper
I replaced the cap, and installed new freeze plugs all around. It worked, but the engine was short lived. I paid 2K for it, and it only lasted 50 miles, yes 5-0. I lost oil pressure, then just stated shaking and knockin like crazy. I'm trying to get my money back, but the seller is saying because I added an aftermarket intake, that it's my fault.
Old Jun 18, 2013 | 01:58 PM
Bad Bad Leroy Brown
That's crazy, did it come with a warranty? If so did it specify no aftermarket intakes? If not you could probably take them to small claims at least.
Old Jun 18, 2013 | 02:02 PM
InfidelReaper
It was a private seller on craigslist. In his ad he said he was a 20 year certified blah blah blah, and the ad did not say "no warranty". But his PayPal invoice did. I am trying to do a claim through PayPal, but he declined giving me a refund because I added an aftermarket intake. He didn't say anything about no aftermarket stuff. Besides...adding an intake doesn't affect the oiling system.
Old Jun 18, 2013 | 02:16 PM
Bad Bad Leroy Brown
Hmm, did you have it looked at to see where exactly it failed in the oiling system? The pump? Regardless that is shady.
Good luck with the claim!
Old Jun 18, 2013 | 02:27 PM
InfidelReaper
I'm pulling it today and tearing it down. He seems to think that I am an F'ing idiot, and I know nothing about engines. A new rebuilt engine doesn't fail after 50 miles unless something was not put together right. And the only thing I swapped was the intake, and put the mechanical fuel pump on, because it didn't come with one.
rannaska
May 2, 2018 09:53 AM
Jarrett Campbell
Apr 27, 2017 06:58 PM
meier63
24
Nov 9, 2014 09:02 PM
FordMan35
Sep 4, 2012 08:07 AM
j400ex18
Apr 14, 2010 10:11 AM
