Dummy Plug.
Old Sep 3, 2012 | 10:45 PM
FordMan35's Avatar
FordMan35
Dummy Plug.
Is this enough of a degraded o-ring to cause a hard start issue? When I had AE hooked up I was getting 275-310 PSI on the high pressure oil side. It would stay there for about 6 seconds of cranking and then start. The pressure then spikes to about 1200, and then down to I think 750 or so.
Old Sep 3, 2012 | 10:49 PM
m-chan68's Avatar
m-chan68
Just curious. Do you have a new dummy rail plug in your possession? If so, take a look at it and decide for yourself. I think it's a no-brainer. By the way, if you don't happen to have a new one in your possession, the part number from Ford is -W302908. And you might want to pick up a 12mm allen head on a socket on your way home as well, since that is the size you will need to install the new plug.
Old Sep 3, 2012 | 10:54 PM
johnblade's Avatar
johnblade
I would say yes,I had the long crank issue and also the no start hot.My passenger side plug looked like that , now
that the new plugs are in it is starting quick.
Old Sep 4, 2012 | 08:07 AM
FordMan35's Avatar
FordMan35
Yup, Got the new one in on Sunday.
meier63
24
Nov 9, 2014 09:02 PM
vasten
1997 - 2003 F150
Sep 28, 2010 09:13 PM
scatgo
Feb 7, 2010 09:45 PM
F350-6
23
Oct 29, 2009 09:08 PM
