C6 transmission question
Old Jun 4, 2013 | 06:10 PM
rgraham52's Avatar
rgraham52
Trailering
I have a 1986 F250 diesel with the C6 auto transmission. If the truck sits for an extended amount of time, it seems to leak transmission fluid.
It has a B&M deep transmission pan.
The two questions I have are:
1. Will having this pan on the transmission effect the stock dip stick? Should the stick read the same, deep pan or not?
2. Is it common to leak fluid if sitting for over a month or so.
Thanks, RG
Old Jun 4, 2013 | 06:19 PM
Gary Lewis's Avatar
Gary Lewis
The depth of the pan has no impact on the reading on the dipstick. It will take more fluid to bring it up to that point, but you still have to have it up to the Full mark.
As for leaks after it sits, I've had that problem as well. And, I didn't solve it - except it did seem to no longer be a problem after I sold it. I never did figure out why it only leaked after it sat, but the leak on mine was from the shift lever, where it comes through the case.
Old Jun 4, 2013 | 10:14 PM
MeanGreen460's Avatar
MeanGreen460
Its probably the front pump seal leaking .If its only leaking a little from sitting I would not worry about it.This was a common problem with c6 trans when they sat for a while
Old Jun 5, 2013 | 01:24 AM
rgraham52's Avatar
rgraham52
Trailering
Thanks for the answers. It doesn't leak all that much I guess, and I just need to run it more anyway.
Old Jun 5, 2013 | 08:04 AM
Gary Lewis's Avatar
Gary Lewis
How long has it been since the fluid was changed? The various additives go away over time, including the one that causes seals to swell. So a change might help, if not fix, the problem. Or, a dose of an additive for seals.
Old Jun 5, 2013 | 09:15 AM
rgraham52's Avatar
rgraham52
Trailering
It was changed a little over a year ago. Mileage wise, that would equate to about 2,800 miles. Additive sounds like a good idea. Any recommendations on which additive?
Old Jun 5, 2013 | 09:19 AM
Gary Lewis's Avatar
Gary Lewis
If it has only been a year and 2800 miles you shouldn't need an additive. The additive in the fluid should still be fine.
Old Jun 5, 2013 | 04:49 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Since it only leaks when it sits long periods of time, sounds like maybe the front seal.
If it doesn't leak that much, I wouldn't worry about it, just check it once in a while and top up. Carefull not to overfill it either, that be bad...
Old Jun 5, 2013 | 08:52 PM
BigBlockF350's Avatar
BigBlockF350
Try AT 205 Reseal. That stuff is great for sealing up little leaks. I've used it successfully in a boat steering system and in a jack. Worked both times for me. I've heard a lot of good thing from other people about it too. Amazon.com has it for under $10.
Old Jun 5, 2013 | 09:05 PM
rgraham52's Avatar
rgraham52
Trailering
Thanks all. It is a small leak, and I hope it's not from me overfilling it. Would that blow out the front seal?
I'll look into AT 205 seal.
Old Jun 5, 2013 | 09:27 PM
IDIDieselJohn
No, overfilling it would make the fluid foam up in air bubbles, then that makes the tranny slip and burn up...
That seal leaking is normal for a 25+ year old transmission that isn't used regularly.
wotan
Jul 9, 2013 09:49 AM
ROKRAWL
Apr 7, 2013 10:04 PM
ownedby2labs
Oct 29, 2009 07:50 PM
tripndrag
Jul 21, 2007 05:01 PM
bryan78f1504x4351mc6A
Aug 1, 2003 09:58 AM
