c6 leaking while sitting in garage. ?
Old Jul 31, 2003 | 12:01 AM
bryan78f1504x4351mc6A's Avatar
um, thought these things mainly leaked while running. truck has been sitting for 3 weeks, leaked perhaps 1 quart. what would be most likely cause ? cant tell where fluid is from, its everywhere,
Old Jul 31, 2003 | 09:30 PM
lilpig88's Avatar
lilpig88
my c6 leaked from the front (right under the torque converter) while sitting. i took it apart and the large o-ring in the front of the tranny had hardened and cracked.
Old Jul 31, 2003 | 11:23 PM
Andysutt's Avatar
Andysutt
It could be a tailshaft seal also.
Or maybe loose pan, or the drainplug leaking (if you have one)
If the fluid is from everywhere, Id check the pan first... as the tailshaft you can usually see a drop or two on the end of it and you can see where it hits the floor.
Old Aug 1, 2003 | 09:20 AM
84-250's Avatar
84-250
check where the dipstick goes into the case. the o-ring might be leaking. the whole pan gets covered in oil.
Old Aug 1, 2003 | 09:58 AM
Andysutt's Avatar
Andysutt
Good one there 84-250 that didn't even hit me until you mentioned it
dirkdriller
Dec 19, 2014 12:53 PM
Bigruss1987
Mar 17, 2014 10:01 AM
BlkBoostedV6
Sep 1, 2013 07:37 AM
76CamperSpecial
Jan 12, 2010 03:04 PM
