Injector Cleaners
Old Jun 5, 2013 | 07:58 AM
Christof13T's Avatar
Christof13T
I have used diesel kleen... lucas injector cleaner... and most recently i did an experiment...
Ran 39 gallons of str8 d2 with no additive... got 14.1mpg
Last time i put fuel in i dropped some " power ups lubricants diesel fx diesel fuel booster".
Got about 1/8th tank to go till next fueling and will see what the improvement is
Old Jun 5, 2013 | 10:04 AM
Joe28443's Avatar
Joe28443
Joe28443
Originally Posted by thomabb
If you get sticked by DOT, you are going to have to explain why your fuel is red. FYI.
Got that covered! I am the DOT! Lol
Old Jun 5, 2013 | 11:05 AM
23larry24's Avatar
23larry24
It could be sticking on the oil side of your injector too, I've run into it before.
Old Jun 5, 2013 | 11:10 AM
hammer65's Avatar
hammer65
My engine is full of fresh Delo 15w40 with about 600 miles on it.
I have know idea about oil side and fuel side. All I know is that it has helped my miss tremendously.
Old Jun 5, 2013 | 11:21 AM
CampSpringsJohn's Avatar
CampSpringsJohn
If additives in the fuel help, then it must be working. What kind of miles do you have on the truck?
Old Jun 5, 2013 | 01:09 PM
hammer65's Avatar
hammer65
176000+ a few
Old Jun 5, 2013 | 01:45 PM
bralos's Avatar
bralos
Couple interesting things.
1. On the Stanadyne. I hear this is the only cleaner that you can run in the truck 100% Pure. A local long time diesel mechanic got me onto the stuff. He uses it before he changes out someones bad injector. He said when someone brings in a truck, mostly ford 6.0 with bad injector he will disconnect the fuel line and run into a gallon of Stanadyne and run the truck at idle for about a half hour to a hour. 9 times out of 10 he said it clears the injector and he does not have to change it.
Also the fact I am adding something that I can run pure make sense to me.
On the ATF in the Oil. We have used that for YEARS in the military. We would not run for long periods but before each oil change. We would add a quart to the oil and let it run up to temp. Then change the oil. So we never ran in the equipment long term but did wonders to clean out the engine for a oil change.
I have only run Diesel Kleen and Stanadyne so can comment on any other cleaners. I use to have to travel a bit to get it also. Once I was sold on it I started to buy in 5 gallon buckets and just refill the 1/2 container that I keep in each truck.
Old Jun 5, 2013 | 02:00 PM
Crewcab Turbo's Avatar
Crewcab Turbo
I definatly want to try the Stanadyne. I looked on the website and they sell 8 oz containers, good for thirty gallons. I'm tired of the larger containers lids leaking and stinking in my tool box. One container per fill up, much cleaner.
Old Aug 7, 2014 | 10:56 AM
BoKnowsDiesel's Avatar
BoKnowsDiesel
Former Vendor
I know this is a year old thread, but I thought I would *bump* it. We have 2 different fuel additives, and and oil additive that will help out with injector performance.
Old Aug 7, 2014 | 04:40 PM
cschulz135's Avatar
cschulz135
A bad ICP can cause a miss or hesitation. Pull the connector and see if it goes away. I run a can of Seafoam through my fuel and oil periodically, I think it's great stuff.
Christian1977
Transit Connect
Dec 30, 2017 10:24 AM
Truckie256
Feb 23, 2015 01:13 PM
Qwatali Hunter
Mar 14, 2011 09:38 PM
florida_1959
Feb 10, 2010 02:43 PM
hdman6
Feb 19, 2006 11:56 AM
