Injector Cleaners
Old Jun 3, 2013 | 06:14 AM
hammer65's Avatar
hammer65
Injector Cleaners
Opinions on best injector cleaners wanted.
Thanks Jim
Old Jun 3, 2013 | 07:58 AM
Snowseeker's Avatar
Snowseeker
Old Jun 4, 2013 | 01:01 PM
bralos's Avatar
bralos
I run this in my 7.3, 6.0, and every diesel on the farm. Have for years and makes a difference. Also even approved for my wife's 2010 TDI diesel Volkswagen.
Diesel Fuel Additives - Stanadyne
Old Jun 4, 2013 | 04:37 PM
Crewcab Turbo's Avatar
Crewcab Turbo
I use Diesel clean, it also boosts Cetaine. I would like to try Stanadyne but the closest place to get it by me is an hour away.
Old Jun 4, 2013 | 04:47 PM
caedo's Avatar
caedo
Iv used all sorts of stuff, stanadyne, ams oil, power service, howes, motorcraft, etc. They have all work great for me. Never gelled, never had a problem. I couldn't tell you which one performs the best though. I'm not that intimate with my truck and injectors.
Old Jun 4, 2013 | 06:54 PM
hammer65's Avatar
hammer65
Thanks everyone, I have been having a problem with a miss at around 1400 rpm for some time, it then seemed to move on up from there, 1400 to 1800 or so.
I usually use some 2 cycle oil in the fuel tank, but went to ATF in the last tank. My miss is almost gone. I feel like it is a sticking injector or 2, and was thinking of maybe something better.
Can't afford new injectors right now. Stanadyne dealer, 100 miles away.
Old Jun 4, 2013 | 06:57 PM
caedo's Avatar
caedo
I forgot to mention ATF, that is a good one too. Keep using it. And get fuel from places that cycle through a lot of it (if you live in a place that does so). Better fuel quality will help with lubrication as well.
Old Jun 4, 2013 | 07:36 PM
F350-6's Avatar
F350-6
These injectors won't stick and develop a miss at those RPM's. If they "stick", it's on a cold start and it gets better after the engine warms up. Make sure what you're feeling at those rpm's isn't electrical or fuel pressure related. Also make sure your engine oil is full, the proper weight, and doesn't have any additives in it.
Old Jun 4, 2013 | 08:09 PM
Snowseeker's Avatar
Snowseeker
A few people mention having problems with the harmonic balancer as well. Very few but still a few.
Old Jun 4, 2013 | 09:25 PM
Joe28443's Avatar
Joe28443
Joe28443
How much and what kind of ATF will work? Mine is hicupping too
Old Jun 4, 2013 | 10:10 PM
caedo's Avatar
caedo
one quart/tank is enough... you could run more if you wanted, these trucks could run on pure ATF... so dont worry about putting too much in.
It isnt a cure all, but it cant hurt.
Old Jun 5, 2013 | 07:04 AM
Joe28443's Avatar
Joe28443
Joe28443
Thanks, I'm gonna give it a shot
Old Jun 5, 2013 | 07:45 AM
thomabb's Avatar
thomabb
If you get sticked by DOT, you are going to have to explain why your fuel is red. FYI.
Old Jun 5, 2013 | 07:51 AM
Snowseeker's Avatar
Snowseeker
I have heard some mentioned the detergents in ATF aren't good for the injectors?
I run only 2 cycle in my fuel.
Old Jun 5, 2013 | 07:57 AM
CampSpringsJohn's Avatar
CampSpringsJohn
I also have heard that long term use of ATF is bad. I'm curious what kind of oil you are using, and how long it's been since you changed the oil.
