3 speed front seal leaking
Old Jun 2, 2013 | 07:06 PM
connork's Avatar
connork
I have a borg-warner t86 transmission in my truck..3 speed on the column with overdrive.
I noticed what looks likethe front seal leaking just a little, and the rest of the trans is covered in old grease.
Pretty sure it's mainly from the front seal..so is this hard to fix?
Do I have to tear apart the whole transmission or can I just drop it and pull the seal out the front?
Old Jun 2, 2013 | 07:57 PM
f5fordgirl's Avatar
f5fordgirl
Pull the transmission, remove the 4 bolts holding the throwout bearing collar to the trans, pull it off, the seal is in the rear part of it. If there are thin gaskets,(shims) be sure to get all of them back in place.
Old Jun 2, 2013 | 07:59 PM
f5fordgirl's Avatar
f5fordgirl
Remove the transmission, take out the 4 bolts holding the throw out bearing cage to the front of the trans, the seal is in the rear part of it. No need to go into the trans.
Old Jun 3, 2013 | 03:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I noticed what looks like the front seal leaking just a little, and the rest of the trans is covered in old grease.
What year is this truck? Your profile says 1983 F150.
Warner T-86 O/D's were not installed after 1964. 1965/71 F100's were available with the Warner T-85N 3 speed O/D.
C5TZ-7052-A .. Front Seal / Warner part number: T89C-54 ~ 1965/71 Warner T-85N.
Front seal located behind (7050) throwout bearing retainer.
BigB9000
Oct 5, 2016 09:44 AM
barnfind 51
Dec 11, 2010 09:01 AM
ADT
Jul 7, 2004 10:02 PM
Night_Mayor
Aug 7, 2003 08:14 AM
red75bronco
1966 - 1977 Early Broncos
May 19, 2003 08:15 PM
