Squeek while shifting..?
Old Jun 9, 2003 | 05:43 AM
rhetor's Avatar
rhetor
Allright, my truck has developed a new noise.
Every time i shift, when i push in the clutch, it lets out this squeek, thats pretty loud, sounds like the leafsprings in the back squeeking like a normal pickup truck. It's really annoying.
It does it under anything more than very light acceleration.
I've ried to replicate it with tapping the brakes, and hitting bumps, but it just wont do it. It does however make a similiar noise on the speed bumps in nuetral.
Is this just suspension, or is it an engine/tranny/transfer mount thats lose or something?
Old Jun 9, 2003 | 11:35 PM
Ford_Six's Avatar
Ford_Six
Probably the throwout bearing for the clutch.
Old Jun 10, 2003 | 06:22 PM
rhetor's Avatar
rhetor
agh... no fun. I don't have an engine lift...
Is that a sign that my clutch is going out? If so, i'm really screwed, because i have absolutely no money for replacing it.
Old Jun 10, 2003 | 07:08 PM
steve83's Avatar
steve83
You don't need an engine lift to replace a clutch, and a new set from NAPA is probably under $200.
But I suspect it's the pedal cross-shaft bushings under the dash. Try squirting some Liquid Wrench, WD-40, or white lithium grease on them.
Old Jun 10, 2003 | 08:14 PM
rhetor's Avatar
rhetor
It sounds like its either coming from the tranny area, or the suspension. Something under the truck.
Doesn't matter how fast i push in the clutch. Once the truck stops accelerating (when i push in the clutch) it makes the squeek. It'll do it when i hold the gas pedal in the same spot too.
Do you think it could be my beat up old shocks? The thing is i can't get it to squeek like that with the brakes or bouncing up n down in the bed.
I tried spirting some oil pretty much all over the leaf springs and connections in the rear. I'm gunna try the front suspension, altho it doesn't sound like its coming from there.
This brings me to another question... Is it normal for the stick and gear selector (transfer case) stick to move a bit more than an inch to the drivers side when i'm accelerating hard? It's twisting with the 300's angry torque, but should it twist that much?
Old Jun 11, 2003 | 11:34 AM
steve83's Avatar
steve83
That doesn't sound like too much considering the length of the lever, but check out your engine & transmission mounts.
Old Jun 11, 2003 | 05:26 PM
rhetor's Avatar
rhetor
I checked the tranny mounts and engine mounts, they seem fine. bolts are tight and rubber is solid.
I did notice tho that the muffler has wrotted out quite a bit, and twists freely in the in tube. It makes that squeeking noise when i twist it, and i'm assuming this is the noise (i'm also hoping).
I'm gunna crack out the welder and tac it in place, see if it stops the noise.
wyowagner
20
Sep 30, 2012 11:21 PM
006f350diesel
Jul 14, 2006 09:12 PM
joeyroe
Jun 3, 2005 08:20 PM
rhetor
17
Dec 15, 2003 05:37 PM
tobyw
Mar 26, 2001 05:55 PM
