Engine identification help!!!
Old May 30, 2013 | 01:05 PM
fordbogger77's Avatar
fordbogger77
I picked up a 79 f150 as a mud truck and the guy told me the motor was a 351c, but after trying to look up ways to identify it all i have come up with is that its not a windsor as it has 8 valve cover bolts. How can i for sure tell the difference between a 351c and a 351m? the only numbers i found on the block are on the passenger side below the exhaust ports, they were dirty and upside down but from what i could tell they are "D71(possibly a "t")-A2-8. any help is greatly appreciated! nothing else on this truck is original so it makes me suspicious of the motor
Old May 30, 2013 | 02:34 PM
85e150's Avatar
85e150
Most likely it's a 351m.
"D7..." is 1977. 351C motors ended in 1974.
Note the big wall above the distributor hole.
Google Image Result for http://www.tmeyerinc.com/images/400%20023.jpg
Note the casting number referenced. Sound familiar?
http://grantorinosport.org/BubbaF250...locknum_01.jpg
But, maybe you got lucky. Check the stroke--not easy to do due to plug angle, but try a stiff wire down the plug hole. 3.5" for 351, 4" for 400. Good luck.
Old Jun 7, 2013 | 07:05 PM
79blake's Avatar
79blake
Look on the drivers side door on the end side there should be codes on a plate to identify it and other things but you have to decode it either online or in a lmc truck catalog
Old Jun 7, 2013 | 07:07 PM
79blake's Avatar
79blake
If its the orig. Motor
Old Jun 7, 2013 | 07:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by fordbogger77
I picked up a 79 f150 as a mud truck and the guy told me the motor was a 351C, but after trying to look up ways to identify it all i have come up with is that its not a windsor as it has 8 valve cover bolts.
How can i for sure tell the difference between a 351c and a 351m? the only numbers i found on the block are on the passenger side below the exhaust ports.
They were dirty and upside down but from what i could tell they are "D71 (possibly a "t" prefix is D7TE)-A2-8 and suffix is A2B
D7TE-(6015)-A2B = 1977/79 F100/350 & 1978/79 Bronco 351M/400 block casting number.
351C installed in 1970/74 Ford/Merc Passenger Cars/Ranchero's only, would not have a D7TE block casting prefix.
351C same engine family as 351M/400. All have 8 valve cover bolts, there is no timing cover per se, just a flat engine cover plate.
The fuel pump bolts to the left side of engine block, its bolt pattern is at 6 & 12 o'clock, the only V8 fuel pumps to have this pattern.
Warranty Plate located on left door face below the latch. Has the VIN, actual W.B., codes for the COLOR/TYPE GVW or MODEL/BODY/TRANS/AXLE and etc stamped on it.
COMPARE the VIN on the Warranty Plate to the VIN on the title/registration to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
4th digit of VIN is engine code. 1977/79 F100/350 & 1978/79 Bronco: H = 351M / S = 400 / LMC's VIN decode info is CRAP!! Use it at your own risk.
JohnBOV43159
Feb 12, 2014 11:29 AM
danger-ranger93
22
Dec 23, 2013 07:26 AM
Fix_Or_Repair_Daily
Jan 6, 2011 10:11 PM
mrm1957
Sep 3, 2003 06:06 AM
pkirchen
Feb 21, 2000 01:29 PM
